'73 LeMans GT optional gauge cluster
Looking for one of these clusters, or the small gas/oil/water gauge from the middle of the cluster.
'73 LeMans GT gauges
In doing some research, looks like the '73 GTO had the same small three gauge set-up between the tach and speedometer.
'73 Gto/LeMans GT gauges
Any condition considered.
if it helps you, if you find a cluster with the gauges and not a tach, you can make it into a tach cluster easily. I cant say for sure (as I never bothered to check the actual part numbers) if the tach is the same as a firebird tach, but once installed you cant tell any difference. so if you find the non tach cluster just get a firebird tach and put them together. you will probably have to run a direct wire to the tach as the printed circuit will be different.
Have a cluster out of a 4spd 73 GTO I parted. The printed circuit will need to be replaced. May have an extra center guage pod as well. No time now, but can dig the tubs out after 1st of the year.
mid-1970s Tri-gauge center cluster
I have this, it's for sale if you want it.
GTO/gauges
PM's sent.
Did you ever have any success in finding the gauge/cluster you wanted? If not, I might be able to help.
optional gauges
Olmanwinter, sent you a pm.
Have a NOS one part# 6496990 correct for 73-75 Lemans models
$100 plus shipping Pic:
gauge
Pm sent.
Pm replied
i have one of these as well but im unsure whether or not its a bolt in application
I have the one on the left,been in the basement over 40 yrs.
