I intend to put a 400 from a 67 Bonnie into a 86 2+2
will the log (cast iron) exhaust manifolds of the bonnie work in a g-body A-body log exhaust will work fine in a G-body I've heard you could Not install a-body log exhausts in a b-body but is the reverse true? |
Looking at my 84GP the passenger side shouldnt matter. If center outlet on driver side maybe interfere with steering column, though I dont think it will. If rear out let I see no issue (the 305 Chevy pos in mine has rear outlet on driver side). Neither style is hard to come by. You can get headers from Indian Adventures fwiw.
Thanks for the reply
I will probably go the trial an errer method was hoping someone had done this before The issue I have with the G-body and its exhaust is the trans brace with its only hump on the pass side since the old 67 bonnie had a good Y-pipe I'd consider reusing it if I can get away with it. Brad in Louisville Ky |
Summit has the double hump crossmembers for just about any tranny you want to put in your G body!
I had a 79 Buick Regal that I put a 400 from a 70 G/P into, the exhaust manifolds from the a-body are what I used.I also used the headpipes from a 70 a-body for true duel exhaust.I mocked up the driverside pipe and marked the trans crossmember ,then took the pipe to a muffler shop to have an offset put in the pipe.
Craig |
Cheapy 3 tube headers work also.
"resurfacing Pa highways 2 long black strips at a time" 78 Olds Cutlass Drag car PONTIAC powered with 440 (destroked 455), th400, 12bolt with spool 4.10z Best to date 10.00@130.92 mph at 3250# 79 Grand Prix, will be new home for the 440 Goal 9.75z@135mph at 2900# 83 Malibu Wagon UUV Crate 350, Custom T5, 8.5 with Auburn posi 3.73z Making it the Ultimate Utility Vehicle Go, tow and show (not so much show, yet) |
Seems the 3 tubes fit everything doesnt it? possible early Firebird headers MIGHT fit but that control arm bracket on the frame might be an obstacle.
