Closed Thread
Old 06-09-2013, 08:14 PM
The Jury's Avatar
The Jury The Jury is offline
Send a message via AIM to The Jury
Default Shaker455 kept me from selling my car.
Hello All,
I don't post here near as much as I used to. Family life, work etc. has kept me busy the last few years. Those things mixed with a continued string of mechanical woes with my 68' LeMans had me contemplating selling the car last summer. I was way in over my head with some issues with my carb and finding truly knowledgeable Pontiac guys in this area is tough. I had about given up hope when I contacted Jeff (Shaker455) last July about reworking my Quadrajet carb. My spark plugs were constantly black, poor idle, lazy secondaries, and just a lack of general knowledge on tuning it. I pulled the carb at the end of July last year and sent it to Jeff along with my distributor. Jeff worked all winter on my carb, and made something that should have gone into the junk pile into a reliable piece of equipment. He went as far as to machine in an ATP adjustment screw into the body along with live testing the carb on his setup until he knew it was right. Not only that, but he suggested adding an air / fuel gauge to my setup. When the carb returned about six weeks ago, I put the carb on and since that time Jeff has spent close to six hours on the phone with me helping me to tune the carb, learn to understand what everything does and how each adjustment works. I can say that with the air fuel gauge and Jeff's help I finally am learning to understand what the car is telling me it needs. The guess work is so much less now and in the last six weeks I have put more miles on the car than I have in the last three years. I am learning to trust the car again and am no longer worried about going home on a tow truck (At least due to carb issues). All this to simply say THANK YOU JEFF. Because Jeff has taken the time to share his knowledge and skill, I am finally enjoying my car again. Jeff does outstanding work, and is very reasonably price for the number of hours he spends working on the carb. Thanks again Jeff, I really appreciate all your work and help, and I think everyone else deserves to know what a great job you do.
1968 Pontiac LeMans- The Jury
"GT...Uh-oh?!"
Pontiac 455
The Following 2 Users Say Thank You to The Jury For This Useful Post:
Old 06-09-2013, 08:16 PM
jmt455's Avatar
jmt455 jmt455 is offline
Thanks for posting this; good to know...and glad to hear you're enjoying your car again!!!
Old 06-09-2013, 08:31 PM
hectore3 hectore3 is offline
I know Shaker455 personally and I can attest he is a class act. Don't hesitate to send your carbs over his way. As he has done a nice one up for me.
The Following User Says Thank You to hectore3 For This Useful Post:
Old 06-09-2013, 09:54 PM
zoso zoso is offline
Thumbs up
he builds badass engines also !!!!!!!!!!
Old 06-10-2013, 10:22 AM
nachomax's Avatar
nachomax nachomax is offline
The Jury,
Jeff also saved me from pulling whatever hair is left on my head, and from possibly selling my car. I also sent him my Edelbrock Q-Jet and helped me dial it in. I am happy with his work and my car.
Old 06-10-2013, 02:02 PM
U4R1A69 U4R1A69 is offline
I need some Q-jet work done. Do you happen to have some contact information?
Old 06-10-2013, 02:11 PM
just send a PM
Old 06-10-2013, 04:13 PM
shaker455's Avatar
shaker455 shaker455 is offline
WOW! Thanks guy's
Carburetor building & modification services
Servicing the Pontiac community over 20 years
Old 06-10-2013, 09:48 PM
frankyboy455 frankyboy455 is offline
Now that is interesting ! Shaker, would you mind telling us a little more about this ? Was it a carb that did not have any APT before ?
Old 06-10-2013, 11:08 PM
shaker455's Avatar
Yes, it's a 1975 unit that had a second power piston with a single metering rod.
They are more labor intensive to convert but once done they calibrate as well as any other later APT unit.
I had to close off passages and machine in a later type APT system.
I have one of these carbs also that goes on my very first car...my 75' Trans Am I've had since a teen.
I pretty much will work almost any unit sent including all thoses Reman units..
Old 06-11-2013, 12:11 AM
Formula8's Avatar
Formula8 Formula8 is offline
X 2. Jeff tweaked my second carb this spring. Can't wait to get back up and running.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
Old 06-11-2013, 07:39 AM
Cliff R's Avatar
Cliff R Cliff R is offline
Modifying a 1975 Q-jet with the aneroid located APT (even the two PP models) to the later deal is minutes work. Block off a couple of jet holes, cut/slot the partition between the PP's, tap for an APT screw, and get a later PP or put a pin in the old one. I do NOT recommend this modification, it can still come up with less than acceptable results. Not my thread, and no need to go into specifics about it. I typically stay away from these units for good reason, they can still be a real PITA to get tuned correctly. The later and very common APT castings will be a better end result every time......FWIW......Cliff
Old 06-11-2013, 05:50 PM
shaker455's Avatar
Didn't go that route you described there Cliffy boy but one thing you are right about is it was labor intensive and of course you wouldn't go there.
Old 06-12-2013, 07:53 PM
Shaker455 does outstanding work both on the machining and assembly side. He helped me as we put together my roller cammed 428. Recommend him highly.
Old 06-12-2013, 08:32 PM
Larry Navarro's Avatar
Jeff has done carb and distributor work for me. Top quality workmanship, fairly priced service and timely turnaround.
I highly recommend him.
Old 06-13-2013, 04:01 AM
Tim Corcoran's Avatar
The Jury
Thanks for posting this is good info. Finding a good Q-Jet guy is hard to find and knowing who can get the job done right is valuable. Cliff Ruggles also has a good reputation but the backlog to get a carb done is quite long.
Tim Corcoran
Old 06-13-2013, 06:41 AM
Brent Flynn's Avatar
Brent Flynn Brent Flynn is offline
Thumbs up
Wouldnt have been easier to find a '76--77 model carb? I know thats what i would've done... I did a '76 Carb for Pont406, went from a demon 750...Car ran within a .1 of the demon, and that was with the heavy exhaust on(Demon was ran with exhaust completely off the car), and that was on the 1st outing, havent had time to fine tune it.... Idles and sounds better than the demon , as well. His car never sounded good, with the demon, and wasnt predictable(60ft wise). I followed Cliff's advice, and used his parts...Thanks Cliff!
1968 Firebird 10.817/122.33 3600lbs trw 455, iron d-port heads/SD intake/q-jet, 9" tires 1.440 60ft
1962 Catalina 4100lbs trw 455, iron d-ports,perf RPM, 800holley, 9'' tires,(12.157@108.91)1.578 60' Oct 2010!!
Old 06-13-2013, 06:58 AM
Cliff R's Avatar
Thanks Brent. I didn't interject my comments above to rain on anyones parade. Just wanted to point out, that converting a 1975/early 1976 model with the aneroid located APT system will NOT get the same end result as starting with the later design in the first place. Those carbs have several differences in the basic design that will not allow the later system to work like it should. This is why I shy away from them for building our custom units, NOT because I'm lazy or don't want to spend the time getting them converted or up to par, etc.
One has to remember that the carburetor building business is a FULL TIME deal for me, and when it's what you have going to pay the bills, spending a lot of additional time trying to get something up to par is not nearly as good of an idea as starting out with something that doesn't need any additional help.
I don't have the luxury of working a good paying "day job" and pissing around with these things in my hobby/lobby time. My comments responding to all threads are to help folks out. Our backlog in the shop exceeds one year, I certainly don't do any of this to push or direct any more work in our direction.
My post was put up here to point out the difference in the two designs, and discourage the readers from going that direction, not to critisize the builder or end user of the carb in question. If you took my comments any other way I'm...........not the first bit sorry about it, pull your head out of your backside and take a couple of English grammer and composition courses!.....LOL.....Cliff
Old 06-13-2013, 12:14 PM
nachomax's Avatar
http://www.youtube.com/embed/ydswJSAfmZM :rolleyes
Spell check would be a nice feature on this forum, right?
Old 06-17-2013, 12:14 AM
69FIREBIRD76MM's Avatar
Default gramer lol
this is funny nacho---dont highjack someone elses thread---this is about someone being satisfy for good customer service and not how to rebuilt a Q-JET ...LOL FUNNY CHIT---VIDEO TOO
Closed Thread
