Old 09-05-2024, 09:49 AM
BILL BOWMAN1's Avatar
Default Head Ccs
If building a roots blower motor from scratch, would you start with 72 or 87 ccs, or does it matter? Would be a pump gas 535, looking to build 900+ hp.
Old 09-05-2024, 10:54 AM
johnta1 johnta1 is online now
With a blower, one would want low cr, so the bigger chamber is better.
Old 09-05-2024, 12:31 PM
Curious George's Avatar
Curious George Curious George is offline
Agreed, especially with the big cubic inches.
Whitmore 462, 670 heads 10.55@125
Same with 310 E D-ports 10.12@131
498 w/single 88 8.53@158
Old 09-05-2024, 05:56 PM
Thanks guy. Now I just need about, 10,000 hours of overtime!😀
Old 09-05-2024, 06:13 PM
mysticmissle's Avatar
i think 72cc e heads flow more then 87 cc e heads for example. if theyre ported its still a consideration. if you havent ordered pistons or heads you have options. especially w a 535 youre going to need dished piston with either size head.
i am building a pump gas 505 to eventually turbo on e85 and race gas. i have 87cc e heads and about 10:1 or hopefully slightly less with the piston a skosh in the hole.
my friends ls stuff is turboed on e85 in the high 12-13:1 compression
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
The Following User Says Thank You to mysticmissle For This Useful Post:
Old 09-05-2024, 07:35 PM
I have wide ports right now, I don’t want to build a custom intake, and want to get away from the offset roller lifters.
Old 09-05-2024, 10:14 PM
blueghoast's Avatar
I went with a 400+60 and big cc-455 heads Comp is 7:89"1
It's pump gas friendly and made around 600-hp with a small
flat-tappet cam that Scott Brown profiled for me, very simualar
to a RAIV cam with a 8-71 blower, very street able and
pump gas 3"42 gear and a tight converter from butler.
GT
Old 09-06-2024, 04:11 AM
charlie66's Avatar
Under 9:1 is best . I prefer the smaller chamber with dish tops to get it there ... Being its a lager cubic inch it might be a challenge thou.. I have 8:4 and its nice an easy to tune.. The higher you go the smaller the tuning window..
My Half AN Injun.....
Old 09-06-2024, 10:24 PM
blueghoast's Avatar
I upgraded the camshaft now I just have to get the car finished that
this blower motor is for. I'm also waiting on a adapter to put on a
wenzler intake (shorten of coarse) seen it done on engine masters
with a big block chevy and made a 100HP more with back-back runs.
I figure with both upgrades hope to see 700HP possibly.
GT
Old 10-03-2024, 05:15 PM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
You could have them machined on a cnc to the big chamber mod like some vendors are offering .. 94/95 cc from the old 72cc chamber.
Kris.
*** THE BIG BRACE is here ***
The Following User Says Thank You to RUDOLFSSON For This Useful Post:
Old 10-07-2024, 08:21 AM
which vendors are offering that chamber enlargement?
1964 540 gto
Old 10-07-2024, 03:53 PM
performerrpm's Avatar
performerrpm performerrpm is offline
Send a message via AIM to performerrpm
use to be sd perf, i had my 72cc eheads done by him with his blower chambers, 96cc. not sure who else does it. gonna run them on a 505 turbo build
i have another set of round port old chamber 72ss i want to do the same with but also go with wide ports
Thread Tools
Display Modes
