Old 02-24-2003, 06:36 PM
Judgemint's Avatar
Judgemint Judgemint is offline
On my 63 twords the back by the wheels were there is frame(not the u channel)I have some major frame rust. My question is does this part of the frame unbolt so it can be removed from the car
Judgemint's Avatar
Old 02-28-2003, 05:58 PM
mechanickeith's Avatar
Can you post a pic so we can see the area you are describing?? Will be able to give a better answer if I can see the area.
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 02-28-2003, 06:20 PM
Judgemint's Avatar
Yea I'll try to get out there tonight with the digicam
Old 02-28-2003, 10:08 PM
Judgemint's Avatar
Here are a couple shots
Old 02-28-2003, 10:11 PM
Judgemint's Avatar
Again
Old 02-28-2003, 10:13 PM
Judgemint's Avatar
this is scarry!!
Old 02-28-2003, 10:24 PM
Judgemint's Avatar
The first 2 are the drivers side, and the other is the passenger side
Old 03-01-2003, 11:49 AM
Judgement,
Might be able to be of some help. My '63 LeMans project is up on big jackstands, will move some boxs & crawl underneath & look at the rear floor board seams & the stamped steel rails & try & help you out with some pics of same area, in decent shape, at least so you will have good idea of where is a good place to start. How far forward on the the stamped steel frame rails, are your frame rails weak?
Old 03-01-2003, 12:44 PM
Judgemint's Avatar
Thanks, that would be great. the damage goes up to about where the door ends in the back, just in front of the jack support
Old 03-01-2003, 12:47 PM
Judgemint's Avatar
more like 18-20" beyond that
Old 03-02-2003, 07:50 PM
Hey Guy! The rusted areas is all part of the unibody! That section of frame is where the pivot point for the rear suspension swing arms mount. The only part of the rear frame area that can unbolt & come out is the upper crossmember that bolts to the body & the tramsaxle bolts to it. What condition is the rest of the car? Is it a convertable or coupe? This will be major work to repair. There is two ways to go about this, cut out the bad area & replace with a good frame/ unibody area from a donor car. Or find a complete donor car with a good unibody [in need of restoration] & swap all your parts to the new car. Sorry to be the bringer of bad news. There is one parts yard here with quite a few 63 Tempest's. If you would like I can go down there & see if they have one with a good rear area & see what they want for it. I have know idea what shipping for something like that would cost. Let me know & I will get you some prices. Keith
Keith Collier
Tech advisor
POCI.org
