Old 04-07-2021, 12:37 AM
lintmann lintmann is offline
Question Throttle Plate ID for a 7040273
Hey Guys I was wondering if someone could help me ID this throttle body assy and the levers. I'm pretty sure it is original to my 7040273 carb but just wanted to be sure.
The casting is 7037174 which I think is correct however it was also used on other quadrajets of the era so that is only a clue. Hopefully it will have some other features that someone could use to confirm it's the correct throttle body assy.
My other question was about the primary throttle shaft/levers. Which one would be correct for this carb? The one that is installed is the one that I believe to be correct. If you look closely at the small levers on the choke side, you will see that it is more pointed that the one that is not installed. Also, the radius of this one where the plates attach in the bore is quite sharp where as the one (green one) that is not installed has an obvious radius. Not that this radius should matter but it might help to ID the correct one.
Any help is appreciated as I'm about to rebuild this carb and want to have it as correct as possible.
Name:	Throttle Plate Assy.jpg
ID:	564235   Click image for larger version
ID:	564236   Click image for larger version
Name:	Shaft Radius.jpg
ID:	564237   Click image for larger version
Name:	Throttle Plate Assy..jpg
Old 04-09-2021, 08:27 AM
scott70's Avatar
scott70 scott70 is offline
Put this in the street section where Cliff will see it.
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Old 04-11-2021, 12:36 AM
3goats's Avatar
3goats 3goats is offline
Need close up of off idle slots. Ram air carbs sit higher in bore otherwise the same
Old 04-13-2021, 10:31 PM
Thanks guys, I've moved this to the Street section and added a better pic of the idle slots.
