Old 04-09-2021, 05:50 PM
PONTYRAT1 PONTYRAT1 is offline
Default 535 Engine of the week
https://www.youtube.com/watch?v=DI0nT3KToq8
Ran across this today
The Following User Says Thank You to PONTYRAT1 For This Useful Post:
Old 04-09-2021, 07:14 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
Nice power level. Not record setting but 1050 is a lot of HP.
Old 04-09-2021, 07:18 PM
slowbird's Avatar
slowbird slowbird is offline
Cool!
Old 04-09-2021, 07:19 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Nice!
Go fast, see Elvis!
Old 04-09-2021, 08:28 PM
Gary H's Avatar
Gary H Gary H is offline
Very Nice build
Old 04-10-2021, 12:17 AM
PontiacJim1959 PontiacJim1959 is offline
So what part/piece of the engine is actually factory Pontiac?
Old 04-10-2021, 12:34 AM
3fastgtos 3fastgtos is offline
Timing cover, distributor hold down, bore spacing, valve cover gaskets.
Old 04-10-2021, 07:57 AM
mysticmissle's Avatar
nice piece for sure. interesting comments about wet decking hiding in there
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
The Following User Says Thank You to mysticmissle For This Useful Post:
Old 04-10-2021, 08:31 AM
4dblnkldude's Avatar
I wonder what it is going into?
Old 04-10-2021, 08:55 AM
GTOLou GTOLou is offline
Did he mention cam lsa??
Old 04-10-2021, 09:32 AM
117 I think he said
1964 540 gto
Old 04-10-2021, 06:57 PM
Vengeance Race Engines's Avatar
Vengeance Race Engines Vengeance Race Engines is offline
What does that matter? It's a race engine...
The Following User Says Thank You to Vengeance Race Engines For This Useful Post:
Old 04-10-2021, 07:07 PM
misterp266's Avatar
I’m thinking that no matter what brand of engine you chose to run, when you get over 1000 HP, you’re pretty much all aftermarket parts.
This is the race section right?
" Darksiders Rule "
The Following 2 Users Say Thank You to misterp266 For This Useful Post:
Old 04-10-2021, 07:35 PM
Jack P. Jack P. is offline
Trying to learn here. Does the LSA of 117 seem high? Why would a LSA of 106-110 not
be more appropriate here? It works well.
Old 04-10-2021, 09:53 PM
pastry_chef's Avatar
Does not seem high to me for that application. I think Langer runs the same.
Very high compression and induction is very strong.
Old 04-10-2021, 10:27 PM
slowbird's Avatar
The better the heads, the higher the rpm equal wider lobe seperation.
My 1050hp 511ci ran 116ls and shifted at 8600-8700rpm
Old 04-10-2021, 11:25 PM
Which is why i said that. At that level, why would it matter that it DOESN'T have stock factory parts on it. Doesn't make it any less brand specific, which was my point.
106-110 work well on cylinder head limited and/or lower rpm applications. Properly designed ports for high rpm as well as bigger inches require valve events that equate to wide lobe separation angles for the rpm needed to make power.
Old 04-11-2021, 12:50 AM
So why not just go with a big inch Hemi and make custom billet aluminum valve covers with the name PONTIAC on them? Kinda like when Pontiac no longer made its own engines and used big block Chevies with Pro Stock "Pontiac" 427 heads. Remember those? That wasn't a Pontiac engine either, but some will say it was because the valve covers had "Pontiac" cast on them - same as my Hemi idea, and probably a much stronger running engine seeing it's a race engine.
Name:	Pontiac 427 BB Chevy Pro Stock Heads.JPG
Old 04-11-2021, 01:25 AM
Dragncar Dragncar is offline
Who in their right mind will call a engine a PONTIAC if the engine under the valve covers is not ? We will never have the power they do, not enough bore spacing.
People who race Pontiacs do it because they are Pontiac die hards.
My kinda folk.
Old 04-11-2021, 01:28 AM
Well then for that matter, why bother making ANYTHING aftermarket for Pontiac at all? It's that sort of thinking that prevents anything from evolving.. I guess next you'll say we should all be using iron heads and 041 cams.... nothing like going backwards, huh. Some of us don't live in that box labeled "50 year old technology", nor do we think that way either.
No offense, but your analogies are way off base and don't apply to the topic.
