I was wondering if anyone knows the original calibration of this carburetor (jets, rods, main air bleeds, etc). Only info I have is that it's a 7029262 replacement.
Just bought it off eBay it looks complete but wanted to double check that it wasn't modified at all thank you. |
Try Jon Hargrove at The Carburetor Shop. He doesn't do emails I don't think but he's active at this site and he takes phone calls.
You may be able to find the answer just exploring his web store. Lots of info there.. https://www.thecarburetorshop.com/
Greg Reid Palmetto, Georgia |
You will need to clarify what carb you need info for.
Your title mentions a Carter # but the Part # you mention, 7029262 is a 1969 Rochester Quadrajet. I can help if its a Q-Jet. I will need to know the application, and the engine size. |
Carter 4852S is an aftermarket replacement Quadrajet for 1969 Pontiac V8īs.
Those usually havs a couple of #īs larger main jets and primary rods, otherwise mimics the 7029262 regarding idle and main airbleeds F.e. the Carter 4887S Quadrajet from the same series have #74 main jets and #46 primary rods. HTH |
It is indeed a quadrajet, but with a Carter part # because Carter made aftermarket service replacements using their numbers. Application for a 69 428, big car.
From my factory Delco Rochester Parts Manual.
Hope this helps. I tried scanning to a pdf but the file was to large to post. Primary Jets 72 Primary Rods 45 rockys1970 |
Thanks guys, was trying to find a good baseline Since it's going on a mild cammed (Crower 60242) YS code 400.
Idle system was modified but the air bleeds weren't. Opened it up and had .038 idle tubes and .052 DCR with a .050 upper idle bleed and .070 lower idle bleed and .110 bypass. Jets were a 71/41 with a .070 main. Suppose I'll try a 73/43 with a BE Secondary as a baseline when I rebuild it. If idle is too rich I have the screw in the air horn for idle air. Last edited by 69400; 09-19-2023 at 05:25 PM. |
Sounds like a good plan.
Can you post pictures on the carb/air horn? |
![]() Quote:
https://cliffshighperformance.com/ |
![]() Quote:
Greg Reid Palmetto, Georgia Last edited by Greg Reid; 09-20-2023 at 12:57 PM. |
@kenth I have no pictures but the air horn looks like any other '69-70 with the primary POE and the 4 brass tubes under it, as well as the idle vent valve on the front. The body has the "updated" smaller float and a hot idle compensator that was plugged with a piece of lead.
