Old 03-26-2017, 04:38 PM
John in Minnesota's Avatar
John in Minnesota John in Minnesota is offline
It should read (So a guy changes the caps.) sorry
  #162
Old 04-25-2017, 10:56 PM
Tom63LeMans's Avatar
Tom63LeMans Tom63LeMans is offline
Default 1963 Interior trim pieces needed
Hi,
Looking for a decent interior center bottom windshield trim piece. This is the one that has the defrost vent openings. I'm assuming the one I need is for a glue in windshield and different from the rubber strip set windshield. I have one that does not match the contour or width of my corner trim(see photo).
Also need upper trim piece for the drivers side rear 1/4 panel for a 2-door Lemans. This is the one with the 4 nails that hold the top of the panel in.
Thanks,
Tom
1963 Lemans -428 +.030, SD Perf KRE heads, turbo 350, 9" Ford 3:90, 11.01@121
1956 Chieftain gasser, 461 stroked 400, SD Perf ported E-heads, turbo 400, Dana 3:70 10.40@125
  #163
Old 04-27-2017, 09:20 PM
mlund888 mlund888 is offline
Default Carburetor?
Hello, any one have any leads on the rare Rochester 4BBL carb for the 4 CYL, the Carter AFB 9400 or what if any Holley would work with the 4BBL intake?
Thank you
  #164
Old 04-27-2017, 10:53 PM
tom s tom s is online now
Check with John from the carburetor shop.He can tell you what AFB could be setup to work with your intake.A Holley would take a adapter.Tom
  #165
Old 05-12-2017, 09:43 AM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
1963 lemans right front fender extention.
  #166
Old 05-14-2017, 02:12 AM
63Banshee's Avatar
63Banshee 63Banshee is offline
Thank you
I think I've got one off an Olds, if you don't mind it not being a perfect match to the original.
  #167
Old 05-14-2017, 02:13 AM
63Banshee's Avatar
I'll fix you up on this. Send a PM.
  #168
Old 05-15-2017, 09:01 PM
hobbygto65's Avatar
PM sent
  #169
Old 05-15-2017, 09:24 PM
63Banshee's Avatar
PM sent
You actually posted a message on my profile page.
  #170
Old 05-17-2017, 08:03 AM
Default 63 Interior trim
I need the upper trim piece for the drivers side rear interior 1/4 panel for a 2-door Lemans. This is the one with the 4 nails that hold the top of the panel in.
Also looking for a decent interior center bottom windshield trim piece or corner pieces that match my center. What I have does not match the contour or width of my corner trim(see photo).
Thanks,
Tom
  #171
Old 05-19-2017, 09:53 AM
ahnuld's Avatar
ahnuld ahnuld is offline
your trim piece looks right, it just won't go in because its hitting the rubber or foam on the windshield.
63 Lemans ride along and drag race.
https://www.youtube.com/watch?v=XMJHMPx7KAQ Gear Jamming
https://www.youtube.com/watch?v=mw7KPRASomg At the track
  #172
Old 05-19-2017, 07:08 PM
That was actually before the new glass was installed. The only way I could have flattened the corners was to lay the trim front edge inside the channel which I'm sure wouldn't be right. Does anyone know if the trim had different contours if windshield was glued or rubber framed? I'm getting ready to modify the corners to match the center piece contour.
Thanks,
Tom
  #173
Old 05-30-2017, 08:02 PM
nrthmiguy's Avatar
nrthmiguy nrthmiguy is offline
Default Passenger Side Toe Kick Panel
Looking for a Passenger side toe kick panel for 1963 Lemans with AC. Preferably blue.
  #174
Old 06-02-2017, 11:56 PM
Sanduners's Avatar
Sanduners Sanduners is offline
Default 4 bbl base
Looking for a 63 four barrel air cleaner base only. Thanks.
  #175
Old 06-05-2017, 10:39 AM
1979birds 1979birds is offline
Looking for a right front wheel cylinder for a 62 tempest. Thanks
  #176
Old 06-05-2017, 02:33 PM
Doug Doug is offline
Thumbs up wheel cylinder
I see that Kanter doesn't have this piece nor does Rock Auto.
If you don't come up with one you may want to check with White Post Restorations at this address:
1 Old Car Drive
Post Office Box D
White Post, VA 22663
(540) 837-1140
info@whitepost.com
They can overhaul your piece and install a brass lining in it. (Never rusts)
Good luck!
  #177
Old 07-04-2017, 09:19 AM
Default Interior trim piece
The last piece I need for my puzzle.
I need the upper stainless trim piece for the drivers side rear interior 1/4 panel for a 2-door Lemans. This is the one with the 4 nails that hold the top of the panel in.
Tom
  #178
Old 07-17-2017, 04:53 PM
dogwalkin dogwalkin is offline
Looking for a fuel door with hinge. 1962 tempest
Sent from my VS990 using Tapatalk
  #179
Old 07-28-2017, 07:40 AM
ta-69's Avatar
ta-69 ta-69 is offline
Looking for the 2 pieces of chrome that covers the pinch welds for a 63 convertible. Can pick up at Norwalk. Call 603 477 7984
  #180
Old 08-08-2017, 08:53 PM
Ok confirmed at Norwalk that I'm not frickin' crazy and do not have the correct center dash trim for my car. Looking for center dash trim that has a ducktail towards windshield consistent to all other 63s with a glue in windshield. See attached picture.
Also still need an upper trim for drivers side rear quarter interior panel. The part with the nail that secures the top of the panel.
Thanks,
Tom
