#81
![]() Quote:
Just as we were walking to the car, it felt strange under my feet, the soles were still on the hall floor! Those shoes hadn't been worn in a long time, I must admit. Kenth |
#82
Having experienced a tire that still looked new fail that was always parked inside (except on multi day car shows) on the interstate back in the early 2000's, I get new tires every 7 years. Luckily, I pulled over before the tire blew, but it had a knot in the tread surface the size of my fist by the time I got the wheel and tire off the car.
My philosophy is, if I can't afford $100 per year (roughly) for tires for my fun car, I can't afford the car. I've got to buy to complete sets of tires this spring (for the GTO and the Camaro) and $1400 should come close to handling the 8 tires including mounting and balancing. I run 17's on both cars. |
#83
Growing up near Woodward, they don’t last very long.
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here Just Say No To 8” Flakes I’m now Unburdened by what has been Burds Literature, nOS factory Brochures, Glovebox literature, & black & blue freedom toppers. |
#84
I've found many people are too cheap to do a lot of things they should be doing, and tires are no exception LOL
#85
![]() Quote:
Rubber doesn’t last long. On our old cars you have to assume that anything that’s original rubber is shot and needs replacement.
-Darryl 1977 Trans Am restomod with E-Rod LS3 and 4L70E. |
#86
I had a Goodyear Wingfoot develop a separated tread at 50 mph and quickly then blow out. It was only 2 or 3 years old. The Firestone Firehawks on my GTO are from 2011 and still ride very smooth and no problems. They didn't even flat spot after sitting without moving for several years. Hate to get rid of them with most of the tread still on them but I guess I have to. I was holding off waiting to restore a set of 14x7 Rallye IIs I have to replace the 14x6s. I know my '69 should have 14x6s but I like the look of the 14x7s.
#87
If you smoke your tires every chance you get you'll need to replace them before age can get to them....problem solved.
#88
![]() Quote:
In 2016, I ordered a set of Coker inner tubes for my Model T. I removed the 45 year old Firestone tubes and installed the new Cokers. Within a year, the valve stems had rotted off the new tubes. I re-installed the 45 year old Firestone tubes and they are still on the car 9 years later. New tires and new rubber are pretty much junk due to the false agenda being pushed about 'the global warming crisis'. Key chemicals have been removed from the equation. That's why even your rubber bands are turning hard and rotting in a few months, where before, they lasted YEARS. I have and do run old bias ply tires with no worries if visibly good. They don't explode and destroy fenders like steel belted radials do!
Jeff |
#89
![]() Quote:
#90
![]() Quote:
My experience, posted earlier, was about tires I purchased in 1995 (that were new old stock Uniroyal redline radials) produced in 1989. |
Thread Tools | |
Display Modes | |
