Old 02-19-2022, 12:17 PM
Pershing Pershing is offline
Default 1967 GTO negative battery cable attachment to the engine
The negative cable ground attachment to the engine: should the cable's metal end be bent 90 degrees? That is what I was told. However, the Ames replacement cable has an end that is straight. Any ideas as to whether to use the cable as is, or bend it 90 degrees? It's a small detail but I want to get it right and photos of this area are hard to find.
Old 02-19-2022, 12:59 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Factory was 90 degrees at the LH cylinder head bolt stud.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A).
2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option.
Old 02-19-2022, 02:08 PM
60sstuff's Avatar
Examples of Factory Original 65-66-67 negative cable 90 degree terminal.
The installation went as follows on stud,
Star lock washer.
Negative terminal.
Nut.
ID:	584504   Click image for larger version
ID:	584505   Click image for larger version
Old 02-19-2022, 02:12 PM
Thanks again! The photos tell it all. Now i know what to do!
Last edited by Pershing; 02-19-2022 at 02:15 PM. Reason: Answer posted prior to me seeing it so no need for my first post.
