EFI Tech All things EFI and making classics modern!
Old 10-27-2006, 01:46 PM
cerino2000's Avatar
cerino2000 cerino2000 is offline
Default Anyone tried the MassFlo EFI system?
Anyone using this for a Pontiac?
www.massfloefi.com
Old 10-27-2006, 01:54 PM
BILTIT's Avatar
BILTIT BILTIT is offline
hmmmm, no pricing.
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Old 10-27-2006, 02:08 PM
wrench's Avatar
wrench wrench is offline
A co-worker of mine uses it on his Cobra Kit Car. Driveability is good, but he claims to have an issue with the Mass air flow sensor location/design. This is causing some higher RPM issues (turbulance??) and low power numbers compared to similar engines using other EFI setups. This is just the story told to me by him, not my personal experience or opinion.
Old 10-27-2006, 02:24 PM
cerino2000's Avatar
Oh they got pricing all right...$3750 for a Pontiac. Cha-Ching.
Old 10-27-2006, 02:26 PM
BILTIT's Avatar
I wonder if it needs a different calibration and/or different injectors?
Derek B.
Old 10-27-2006, 03:06 PM
wrench's Avatar
He runs a programmable engine control system. He had it on a chassis Dyno and the Mass air flow reading was all over the place at higher RPM. It runs great when cruising. I think he is working on something to move th MAF sensor away from the intake to smooth out the airflow going through it.
Old 10-30-2006, 09:46 AM
digger1978 digger1978 is offline
Cha-ching $3750 isn't that bad of a price. Butler's systems start at $3500 with no intake, distributor or coil. However they do include a fuel pump and filter. It might depend what parts you already have. You would think all the kits would be relatively the same price...they use many of the same components except for the intake and distributor.
Old 10-30-2006, 11:46 AM
65Mark 65Mark is offline
If you are into to DIY check out Megasquirt EFI. That is the way I am going I think, you can also buy it assembled if you don't want to solder. It takes a while reading to see what it's all about but cost s good, and you also learn how to fix it yourself if needed.
Here's the FAQ page..... http://www.megasquirt.info/
Old 10-30-2006, 05:07 PM
vtxman's Avatar
vtxman vtxman is offline
65Mark,
I can't get your link to work for Megasquirt. Do you have another address for them?
Thanks, Dave
Old 10-30-2006, 07:02 PM
BILTIT's Avatar
Worked for me?
Will be the way i go aswell.
Derek B.
Old 10-30-2006, 10:43 PM
Hammered's Avatar
Hammered Hammered is offline
I think the Butler kit is the only off-the-shelf kit out there. You can assemble the same for much less as I did. I have a bunch of info on my website below.
1967 Firebird Convertible Factory 400/4spd
Now 462/5spd Fuel Injected
http://1967firebird.atwebpages.com/
Old 10-30-2006, 11:43 PM
Here ya go Dave
http://www.bgsoflex.com/megasquirt.html
I hope that works for ya, there are several websites for them. They'll have stuff for the tranny too next spring? I hope they have the sequential injection and tranny done by the time I am ready for it.
Old 10-31-2006, 12:06 AM
vtxman's Avatar
Thank You, 65Mark......I am able to access it now. Thanks for the info.
Dave
