Old 03-22-2023, 02:20 PM
jamesq's Avatar
jamesq jamesq is offline
Default 1963 9.3" 3.42 ring and pinion
I need a 1963 9.3" 3.42 ring and pinion in good shape.
Thanks,
James Q
James Quayhagen
1963 Bonneville Safari - Nocturne Blue, 4-speed
Old 03-22-2023, 08:36 PM
tom s tom s is offline
A friend passed away and has 4 pumpkins sitting there,If the 3.42 is open I would sell the gears out of it.Will see them the end of next week.Tom
Old 03-22-2023, 08:45 PM
jamesq's Avatar
Thanks Tom,
The rear is apart and the car is tying up a buddys' lift so we will probably bead blast the originals if we can't find a ring and pinion pretty quickly.
James Q
James Quayhagen
Old 03-22-2023, 08:51 PM
jamesq's Avatar
This is what the original ring looks like. My buddy says it looks like the car sat in the same spot for quite a while.
James Q
James Quayhagen
Old 03-23-2023, 11:25 AM
misterp266's Avatar
Don’t forget about Fabcraft. Not sure where you’re getting all the other needed items but they have it all. If you need to move the car, put the axles back in with a piece of pipe over both ends to hold them inside until your pumpkin is fresh.
https://fabcraftmetalworks.com/produ...-axlera4-0342/
" Darksiders Rule "
Old 03-23-2023, 12:55 PM
I believe Brad sold the 9.3 stuff to Dave at J&S gear in Huntington Beach CA?Tom
Old 03-23-2023, 02:23 PM
misterp266's Avatar
Didn’t say Brad, I said Fabcraft. It may well be J&S Gear but on eBay it’s Fabcraft. Brad goes by 4speed427 on eBay and sells some SD related stuff still.
" Darksiders Rule "
Old 03-23-2023, 05:49 PM
jamesq's Avatar
I did speak with Fabcraft and they have a 3.42 ring and pinion. However, it is not a direct bolt-on to my original posi carrier.
I think I would rather find a good original 3.42 ring and pinion than do a work around.
The bead blasting came out okay, so it will be put back together with the original and I will continue to look for another as insurance! I won't be dropping the clutch at 4000 rpm anyway!
Tom, I would be interested in your friends 3.42 if it becomes available.
Thanks,
James Q
James Quayhagen
Old 03-23-2023, 06:08 PM
Will get over there after his service.Tom
