79" T/A tilt column
I'm looking for a diagram of a 79' T/A tilt column. I have one I'm trying to replace the bearings on and I can't find the part numbers for the bearings. Can anybody help?
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
Which bearings? It's not as simple as supplying a diagram, you still have to go searching for the part numbers for each item. Do you need the diagram? Do you have the 76-81 Parts Manual?
Here's a diagram anyway. Tilt Steering column diagram 1979_81 by Ben, on Flickr Tilt Steering column diagram 1979_81 part numbers by Ben, on Flickr |
Many diagrams for second gen columns show a bearing. None of my later even an 81 tilt Z28 column have a bearing, more a plastic bushing I couldnever find a part # for
Thank you! Looking at the diagram above it appears that I need the bearing listed as #2. I don't have a 76-81 parts book so I can't look up the part number.
Possibly #26001827.
Thread Tools | |
Display Modes | |
