Old 02-25-2016, 02:47 PM
Mike Mike is offline
Default 67 GTO fuse box
I'm looking for a diagram/pic of a 67 GTO not Tempest fuse box, I have the tempest and its different then the GTO. I cannot read the lettering on my box and I'm trying to do some Trouble shooting. Any help would be helpful, THANKS!
Old 02-25-2016, 06:40 PM
Jeff Hamlin's Avatar
Mike,
I don't have a copy on file but page 12-20 of your service manual will show the one and only fuse block used on the Tempest/GTO/A-Body.
See figure 12-17
Cheers
Old 02-25-2016, 09:54 PM
Old Goat 67's Avatar
Here you go.
Name:	FUSE BLOCK(Large)-Ignition.jpg
Old 02-26-2016, 11:59 AM
Thanks old Goat but that is for a Tempest. They are different. I went to my service manual and it only gives the fuse size and NOT in the correct order. I'm not able to read the fuse box. Tempest has 2 small fuses GTO has only big.
Old 02-26-2016, 01:08 PM
DogMeister's Avatar
DogMeister DogMeister is offline
Default They're the same
Mike, maybe we don't understand what you're looking for, but the Tempest and GTO fuse boxes are identical. The cars are the same except for the engines and trim. What fuse issue are you trying to sort out? Old Goat's picture is correct for the Tempest and GTO. when you mention 2 fuses versus 1 what are you referring to?
461 Stroker Built by Me -
Old 02-26-2016, 06:39 PM
IDK, a GTO IS a Tempest. No difference in the fuse panel. You sure your fuse box hasnt been hacked? ; )
Bill Nye.
Old 02-26-2016, 07:40 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
Default 1967 A body Pontiac Fuse Block
Try these:
Name:	67 Lemans Fuse Box.jpg
ID:	422061   Click image for larger version
Name:	67 Lemans Fuse Box Shop Manual Page.jpg
Peter Serio
Owner, Precision Pontiac
Old 02-26-2016, 08:24 PM
Peter,
Any knowledge as to why the block shown has been altered/modified?
note it is missing the Heat/AC control (20A SMALL) fuse, was this standard on None AC models??
If so I can't say I've ever noticed this til now.
Old 02-26-2016, 09:05 PM
I cannot discount that it's been altered. Car was frame off in the past. What OLD Goat sent was what I was looking for with describing what the fuse was assigned to. my box was washed out and had room for only large . Jeff H. might of brought up a good point.
Old 01-12-2023, 05:42 PM
Rdanduran Rdanduran is offline
Is there a part no. In your manual for the 67 lemans fuse block?
Old 01-12-2023, 07:08 PM
Tim john Tim john is offline
I replaced my original dash harness with a new M&H and believe I still have the original squirreled away if you need anything additional. My car: 67 GTO H.O. four speed.
Tim john---
Old 01-12-2023, 10:34 PM
Part # for 1967 fuse block T/6 & T/8 is 6288675. For those of you with a 1965-1966 it is 2989804.
Old 04-14-2023, 11:13 PM
sixty7gto sixty7gto is offline
Tim john---
Hello, Did you ever dig out that old Fuse Box belonging to your GTO? I would love to see a picture of the front and back of it. I looked in the service manual and the picture shown is not the same as what I have in Mine. Also, I would like to know the 4 numbers stamped on the upper right corner.
I'm also looking to purchase a replacement for mine, it is pretty beaten up.
