Old 11-11-2022, 10:21 PM
Green Hornet's Avatar
Green Hornet Green Hornet is offline
Default vintage brake booster question
I pulled this off the shelf today....for an exploratory...
I'm guessing 59-61 GM.....
The master was still attached......and it took some serious work with a big hammer and chisel to remove it.....(even after I took the bolts off...)
The inside was just loaded with that white powder.....
Was this somebody's cocaine stash...or just decomposed diaphragm.etc.?
Old 11-11-2022, 11:28 PM
Was the master cylinder aluminum? Looks like corroded aluminum. Would also explain why master was so hard to get off. Corrosion between 2 dissimilar metals.
Old 11-11-2022, 11:59 PM
nope....master was definitely cast iron...and booster is stamped steel
Old 11-12-2022, 08:00 AM
stevep's Avatar
stevep stevep is offline
That is a 1959-1961 Bendix booster, You need a Bendix master to go with it.
Old 11-12-2022, 09:40 AM
So that is where the white powder came from?
Old 11-13-2022, 09:04 AM
stevep's Avatar
Who knows at this point.
Old 11-13-2022, 01:29 PM
That's precisely why I posted...Figured somebody here might know.
Old 11-13-2022, 06:22 PM
stevep's Avatar
Contact the Power Brake Exchange and see if they can shed some light on it.
Old 11-14-2022, 12:58 AM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
Only one way to find out if it is cocaine... :O
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
The Following User Says Thank You to nUcLeArEnVoY For This Useful Post:
Thread Tools
Display Modes
