OHC-6 TECH Over Head Cam projects, questions and advice.
Old 12-22-2022, 03:08 PM
Hokie1984 Hokie1984 is offline
Default Accessory Drive Shaft Seal
I saw a recent post on accessory leaks so I thought I would share my recent story. For years I fought a leak from my accessory housing shaft seal. Not bad, but several drops per day. Anyways, I replaced the seal several times from different manufacturers only to find it leaked again. The seal in question is SKF-6130 (0.937 x 0.188 x 0.625). Different manufacturers have different part numbers, but they are basically the same type seal. If you go into the SKF catalog for the SKF-6130 you will find it is a HM14 type seal. Interestingly the description for an HM14 seal is as follows “Non-spring-loaded seal for grease retention or dirt exclusion in applications with slower speeds. Not for oil retention. Install with lip facing outward for maximum dirt exclusion. Typical applications are conveyor rollers and vehicle wheels. Heavy-duty type TL handles severe conditions such as disc harrows.” From that description I questioned its application and yes the SKF-6130 is not a spring-loaded seal, in fact none of the ones I had installed were spring loaded. So, I decided to see if I could find a spring-loaded seal in the right dimensions. The short answer is no unless you want to go with a 50-year-old GM replacement (very hard to find).
Not finding a replacement I researched what was the smallest spring-loaded seal available for a 5/8” shaft. Ultimately, I landed on the SKF-6134 (0.987 x 0.250 x 0.625) but that meant I needed the housing machined. Biting the bullet, I had my housing enlarged approximately 50 thousands to accommodate the 0.987 dimension. This allowed me to hammer in a new seal plus the 0.250 dimension is closer to the original GM dimension. Long story short, no more leaks.
The Following User Says Thank You to Hokie1984 For This Useful Post:
Old 12-22-2022, 04:33 PM
Jeff Hamlin's Avatar
Thumbs up Good Info;
This a good tip. Thanks for sharing.
I've been using the seals shown that you mentioned and so far so good,
but I do like the "Spring" seal option.
ID:	603925   Click image for larger version
Name:	SEAL INSTALLED.jpg
Shiny Shiny is offline
Nice detective work! Unfortunate you couldn't find a drop-in replacement but glad you found a solution.
Old 12-22-2022, 09:18 PM
jrunner jrunner is offline
Great information and thanks for sharing can’t stand leaks my family members use to yell don’t park that damn car in my driveway.
