1980 turbo pace car rear end paint
question was the rear end painted semi gloss black on the 19802 pace car trans am
I thought the pictures i have seen is the rear left the factory natural As always thanks again |
Natural cast steel center, natural steel tubes. On the 3.08 posi coded rears, believe there was a large orange inspection mark on the bottom of cast center housing. Will ck a few original '80 housings to confirm.
thanks as always
mine doesn't look pretty but I don't to paint where there was none Always looking to make better but original |
Here are some pictures of a 1980 F Body (Z28)
with under 200 miles |
you can always use paint colors to match the natural finishes and prevent ugly rust.
Here are two from a 1981 Turbo TA. Found them after sand blasting
