Rusty fuse panel clips
Anyone had success cleaning them? I was considering a small brush on a dremel or maybe trying to clean with some rust remover liquid. Searching around on here it seems some have used CLR but it did remove the lettering.
Mine might be too far gone, but I suppose it’s at least worth a try. No factory replacements for these I assume? Other than just cutting all the wires and splicing with fuses I guess. |
Following......I have the same issues...
I bought fuse clips from Del Mar Wire four or five years ago.
Give them a call. https://www.delmarwire.com/circuit-p...n/fuse-blocks/
Ed 1968 GTO (Thanks Mom) 2006 Silverado 2007 Cadillac SRX 2015 Chevy Express |
Michael Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done... |
The Following User Says Thank You to mrennie For This Useful Post: | ||
I wonder if you could disconnect the harness, then un-bolt the fuse box and soak it in a container of Evaporust. My only concern would be if it takes the lettering off.
I bought a bunch of the clips from Delmare Wire and replaced them. Kind of tedious, but doable. There are a few of them that can't be replaced since they are atypical. You a good crimper that is the right type for the job. You really only have to cut off the last 1/4" of the wire ... most of the time. Some may have corrosion that runs up the wire a bit that might have to be trimmed off a bit more.
I'm World's Best Hyperbolist !! |
Works for me in Chrome and Brave. But I can tell it's got a strange "fade in" effect applied which might present problems for some browsers.
I cleaned the rust off mine this last weekend with ketchup, vinegar and salt.
Sent from my iPhone using Tapatalk |
The Following User Says Thank You to fairwayhit For This Useful Post: | ||
Wow, impressive.
"At no time did we exceed 175 mph.” Dan Gurney's truthful response to his and Brock Yate's winning of the first ever Cannonball Baker Sea-to-Shining Sea... Still have my 1st Firebird 7th Firebird 57 Starchief |
I wish I would have taken a “before” picture. They were pretty rusty. I was amazed at how fast it worked. I just put some vinegar and salt in the ketchup base and it was still thick enough to stick on there. Like a gel. Literally in 5 min I washed it off really good with water. Then I blew it all dry with compressed air and went over everything with some rubbing alcohol and more compressed air. Pretty amazing how clean it got. There is still some pitting from the rust, but it looks way better. Wanted to make really sure I got all the salt and water off. I put some dielectric grease on all of the terminals and exposed wire. Sent from my iPhone using Tapatalk |
That 8 position Hella you linked is the same as the one I got from ebay. I Cut the ears off and ditch the cover to make it fit.
