Old 03-14-2023, 10:51 AM
neasb neasb is offline
Default Installing front lamp harness tips- 65 GTO
Any recommendations on the easiest way to access the harness specifically where it runs across the front of the radiator support? Can't see a good space to get my hands without removing the grills.- thanks
Old 03-14-2023, 11:19 AM
Ok, it looks like if I unbolt the radiator i may be able to move it just enough to get my hands on the harness. May not even have to disconnect radiator hoses. Battery will need to come out too.
Old 03-14-2023, 01:08 PM
No need to respond, i found access under the car. -thanks
Old 03-14-2023, 03:13 PM
mzbk2l's Avatar
mzbk2l mzbk2l is offline
Just for future reference for when this thread turns up in search results, how did you do it?
Mike
Old 03-14-2023, 04:16 PM
I haven't done the job yet, but I climbed under with my creeper and was able to get my hands on the harness from underneath. It appears the tedious part would be removing and replacing the harness support straps. It looks like the battery would have to be removed too. Hopefully others will chime in
