Old 03-22-2023, 02:19 PM
kpbrown31 kpbrown31 is offline
Default Help finding a wagon door spring?
No luck with Ames, OPGI, or Restoration Specialties. According to the tech guy at Ames, he checked a GM parts book and it appears to be a GM part number of 4301722 (RH) or 4301723 (LH). It’s a type door latch spring that came off the inside door latch mechanism on my 66 Catalina wagon. He also said it appears they used the same spring on 62-67 Chevelle wagons and El Caminos.
Restoration specialties has a similar looking spring that I am considering ordering and just seeing if I could bend it how it needed to be, but I also wondered if those springs would actually bend or just try and break. Or curious if anyone might know where to find them before I start trying to hunt down cars in a salvage yard.
As you can see in my pictures one leg is broke off. From what I can tell it applies pressure in the lock to keep the detent lever pushed down to latch?
Thanks!
ID:	609382   Click image for larger version
Old 03-22-2023, 02:33 PM
mgarblik mgarblik is offline
McMaster-Carr sells a variety of little springs of that variety. They are a industrial supply warehouse. You would need to measure an old spring for wire diameter, number of coils and leg design. But there is a good possibility they would have a spring that would function for you. They have a great on-line catalog but this is not car parts so you have to have your measurements.
Old 03-22-2023, 05:24 PM
misterp266's Avatar
Is this close?
https://www.classicindustries.com/pr...s/9720761.html
Fits ‘67 - ‘72 El Caminos.
I look at Chevy sites for things to fit my ‘63 Safari. A lot of stuff interchanges but they won’t list it for a Pontiac. Ecklers has a lot of stuff too.
You may be better off looking for a complete latch assembly.
" Darksiders Rule "
Old 03-22-2023, 08:16 PM
Is this close?
Yeah I may just need to try something that’s close and see if I can make it work. Never thought about checking Ecklers or other sites. I definitely think searching for the Chevy compatible part will be my better option.
Old 03-22-2023, 09:52 PM
Torsion springs from McMaster-Carr
https://www.mcmaster.com/products/torsion-springs/
