Old 03-20-2023, 04:38 PM
Dave1969 Dave1969 is offline
Default Fiberglass spoiler question
I have a rear spoiler for my 69’ GTO and you can feel a wave across the top of it. I put a straight edge on it and I have approximately 1/16” dip in between the internal ribs. I feel you will see this horribly if painted. The question is can I use regular bonds skim coated and sanded or should I do something else. Any assistance is appreciated.
Old 03-20-2023, 06:32 PM
You might get more responses in the Judge section as the spoiler was never offered on regular 69 GTO’s. The issue you mention is a common problem on spoilers. Given how much fiberglass expands and shrinks I’d have a fiberglass guy fix it rather than use any kind of body filler designed for metal panels.
1969 Fbird (Base, 350 & Sprint Cvt’s - 400HO & TA Hardtops)
1969 LeMans (2dr & 4dr Hardtop and a Cvt)
1969 LeMans Safari 2 seat Wagon
1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop)
1969 Catalina (3 Cvt’s & a 2dr hardtop)
1969 Ventura 2 Seat Wagon
1969 Executive 4dr Sedan
1969 Bonnie Cvt
1969 Bonnie 3 Seat Wagon (2 of them)
1969 Bonnie Brougham (4dr Hardtop & Cvt)
1969 Grand Prix SJ (2 of them)
1969 2+2 2dr Hardtop (Canadian model)
Old 03-20-2023, 09:15 PM
That’s what I was thinking maybe using a fiberglass resin to even it out
Old 03-21-2023, 05:42 AM
HoovDaddy's Avatar
HoovDaddy HoovDaddy is offline
I'm pretty sure it's made of SMC, not fiberglass. Use Evercoat "Vette Fill and Adhesive" to fill the area. Make sure the label states fiberglass and SMC. Remove paint down to the bare substrate and apply the filler. You use this just like regular body filler, except this is designed specifically for SMC anf fiberglass only. When you sand bare SMC you will need a SMC compatible primer. It can be built up quite thick if needed. It will not work on steel.
https://forums.maxperformanceinc.com/forums/attachment.php?attachmentid=585876&stc=1&d=1646964  761[SIGPIC]
Old 03-21-2023, 07:19 AM
Thank you that is the exact kind of information I was looking for.
Old 03-21-2023, 07:34 AM
HoovDaddy's Avatar
You're welcome. Forgot to mention, as long as it is an original spoiler.
Old 03-21-2023, 03:39 PM
My spoiler is a fiberglass aftermarket one.
