OHC-6 TECH Over Head Cam projects, questions and advice.
Old 03-26-2023, 11:52 AM
Lee's Avatar
Lee Lee is offline
Default Engine lift points?
Hi,
I'm about to pull a Sprint 6 out of a '68 Firebird.
Are there preferred points to hook up a chain to the block? I have the intake/exhaust removed. I don't want to commit a faux pas, and connect at some fragile point of the motor!
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
My webpage http://lnlpd.com/home
Old 03-26-2023, 01:07 PM
66sprint 66sprint is offline
If you are using a single chain with just 2 bolts for the PS find the 3/8” bolt boss on the side of the head either at the front of the head or right behind the coil.
On the DS since the intake and exhaust are off, just use one of the manifold bolt holes towards the rear of the head that allows you to balance the lift.
Avoid the power steering, alternator and AC mounts as they are all cast aluminum.
The Following User Says Thank You to 66sprint For This Useful Post:
Old 03-26-2023, 04:52 PM
Jeff Hamlin's Avatar
Agreed, I like to keep the chain short so it lifts up about 2" above the Cam Housing and hook it in line with the back of the carb.
This point is almost a perfectly balanced lifting point for just the engine, No trans.
Old 03-26-2023, 06:53 PM
Lee's Avatar
Lee Lee is offline
I got it - thanks!
Old 03-29-2023, 09:00 AM
Doctor john Doctor john is offline
Can the engine without trans be removed from a 67 LeMans without removing hood? I know it requires rotating engine during removal.
Old 03-29-2023, 09:19 AM
I would not try it, I don't think it is possible.
