Old 03-27-2023, 09:20 AM
mysticmissle's Avatar
Default 1969 45 cylinder heads
I think these are 400 2 bl heads, very little info that i can find on them. I have seen conflicting info on valve size? are they small valve like 46s? anyone know chamber size? I bough a complete motor, might take it apart, but its so clean in the valley and cylinder heads, that i think its already been gone through. Might just verify on the run stand that its healthy
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 03-27-2023, 10:07 AM
25stevem's Avatar
25stevem 25stevem is offline
Jeff I have a set of those I use as a development casting.
They are 1.96” with the normal 30 degree seat, and the exh is 1.66”.
The chambers are about 85 CCs.
Here are the stock intake and exh flow numbers.
.100”—-71.7—43.8
.200”—-133.4—89.9
.300”—-172.2—120.2
.400”—-191.3—149.5
.450”—————156.4
.500”—————161.3
.550”—————166.6
I do stuff for reasons.
The Following User Says Thank You to 25stevem For This Useful Post:
Old 03-27-2023, 10:51 AM
Formulas Formulas is offline
sounds close to the #47 and #11 heads
The Following 2 Users Say Thank You to Formulas For This Useful Post:
Old 03-27-2023, 11:09 AM
25stevem's Avatar
In looking at my notes deeper the 45 casting could be 45 degree intake or 30 degree seat, this being determined by the block code..
The YA coded 400s got the 30 degree seat.
The 1968 #15 head is darn near the same, but only was made with a 30 degree seat.
Old 03-27-2023, 11:17 AM
I found ref too 45* seats on Wallace I think
That’s all I found
1964 540 gto
Old 03-27-2023, 11:42 AM
25stevem's Avatar
What’s the block code you have ?
Can you knock a intake valve out of it and post back on what you find?
Old 03-27-2023, 11:55 AM
It’s a yb cast late 68 just like heads
1964 540 gto
