Old 03-27-2023, 12:06 PM
Yellow Bird Yellow Bird is offline
Default Radiator Help
Does anyone have a diagram of the 77 transam 400 radiator that they can post? It has a tag with FB attached to the side. I need to know how to reinstall it to the core support. Hopfully with torque specs. Thanks
Old 03-27-2023, 11:04 PM
Trevor78 Trevor78 is offline
This is from the 76 manual, it didn't change. The radiator still sits inside the shroud using rubber mounts top and bottom, the shroud bolts to the support top and bottom.
Screenshot (2) by Ben, on Flickr
Old 03-28-2023, 07:07 AM
YES, exactly what I needed. Thank you so much Trevor78. Your post is appreciated, Yellow Bird
The Following User Says Thank You to Yellow Bird For This Useful Post:
