Old 03-29-2023, 01:55 PM
wakesupremo wakesupremo is offline
Default Sorry not Pontiac but 4L60E
Sorry. I know this is a pontiac site but I need some info. I have a 2003 chevy Silverado Z71. The transmission has finally given up (320'000miles so not done bad). I am trying to remove it and I think I have all the bolts out but it wont move. I have taken the 2 bottom bolts out and 2 each side above those, are there any more bolts that I can't see??? Everything else is removed as best as I can see. Thank you.
Old 03-29-2023, 02:02 PM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
I think there are a couple behind the intake manifold. Hard to get to. I changed the converter on my 2000. It was a bit of a pain.
Old 03-29-2023, 03:53 PM
JLMounce JLMounce is offline
If it's a bolt on bellhousing model, there should be 2 near the top of the bellhousing. There should be 8 total bolts.
-Jason
1969 Pontiac Firebird
Old 03-29-2023, 08:16 PM
Schurkey Schurkey is offline
WHAT ENGINE??? Diesel? Gasoline?
For the record, when I removed the 5.7L TBI engine from my '88 K1500 w/THM700 trans, (6 bellhousing bolts, 3 torque converter bolts) about twenty years ago, I had to jump up and down on the engine to get the seized dowel pins to release from the transmission case.
The Following User Says Thank You to Schurkey For This Useful Post:
Old 03-30-2023, 01:37 AM
Its a 5.3 gas motor. Thanks.
Old 03-30-2023, 03:39 AM
Should be the same 6-bolt pattern as a traditional SBC, with one bolt moved to top-center instead of near-top, right side. There may be additional bolts into/near the oil pan, maybe one to the left of the top-center bolt.
I've never had an LS engine/trans apart.
Old 03-30-2023, 11:11 AM
Sirrotica's Avatar
Sirrotica Sirrotica is online now
There is the one at the very top of the bellhousing shown in this picture, did you remove that one? If so then I would guess the dowel pins are stuck. GM did change the bolt pattern from the SBC to the LS architecture in the rear, 5 bolts are the same, one has been moved to the very top of the pyramid.
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
