Emergency Flasher button won't stay in
Just completed (almost) the LED conversion for everything except the headlights on my '67 GTO. Turns out one of my flashers is bad, easy fix. But my emergency flasher button won't stay in. The flashers work as long as I hold it in but it won't stay.
Any ideas?
461 Stroker Built by Me - |
Did it stay in before the LEDs? Mine started doing that in my '67, Cutlass (probably the same steering column?) And I ended up having to replace the turn signal cancel switch in the column.
Mike |
Can't say. I don't recall trying it before. I just removed the cancel cam and turn signal switch, and it will stay on if you finagle it right. We'll see when I get it back together.
