Replacing '68 Carpet
I want to replace the carpet on my '68 GTO which is not cut correctly. It a 3 speed with the console. I have good information about the cuts for the seat brackets. Does anyone have some pictures about fitting it over the hump? Thanks, MaxWT
If you remove the seats and let the carpet sit in there for a while it will help it conform to the contours better. Then you will be able to get a better idea of where you need to "make" it fit. I see you're in Ohio...if you can do this in a heated garage it will conform better to the contours of your floor and the hump.
Yes, I would not try this in a cold garage. Thanks for the reply.
Also...once you have the carpet more or less conforming to your floor you can install the seat bolts (I use longer than stock for this trick , not to install seats) from underneath the car and when they lift the carpet a bit you can cut an X in the carpet to help locate the holes after the carpet is final installed. You can do the same thing for seat belt bolts but it's a bit trickier. The drive shaft may be in your way.
Greg Reid Palmetto, Georgia |
Thanks for sending the picture. Do you know if original carpets had a "bare floor" space between the seat brackets cut out of the front carpet?
Thanks for the way to mark the location of the seat bolts/nuts. |
I've never seen any bare floor on any GM car from this era...so, I'd say 'no'.
Another tip...Use an old soldering iron or woodburning iron to make holes in the carpet for seabelt bolts and so on. Prevents unraveling. For the seat mounting brackets themselves, I made the factory style 'L' cuts so that foot of the bracket remains hidden under the carpet but bolt is accessible for removal, if needed, by simply raising the flap of carpet away from the mounting point.
Greg, Thanks for answering my questions and posting the picture.
MaxWT |
No problem. I have a drawing somewhere of the carpet cuts too if you need that.
Bare space under bucket seats...
Attached pic is of my two owner, Fremont built 1966 442's original carpet set after I removed it.
It DID have a cut out from the front section of carpet under each seat that left a small section of bare floor exposed. On my new set I did replicate the cuts to hide the track feet (details highlighted), but I didn't cut out the part that exposed the floor. I've done other carpets, but never had another one with the oem carpet still in it, so i can't say for sure if this was common or not. I've seen the cuts for the track feet before, but never the bare spot under the seat.
Ben R. 2004 GTO - the daily 1966 Olds 442 - the toy 1953 Chevy 5-Window Truck - the heap |
ranbow, I really should have known better than to say 'no'... The fact is, I would not have paid that much attention to that detail back when these were daily drivers.
By the way, your photo on the left is one of the pics I referenced for my carpet cuts. I found it somewhere online.
I just remember the bare floor part because i thought it was odd- which is why i took pics of it.
A heat gun is your friend as the new carpets take some work to lay well on the hump. Let it sit as suggested but it must be warm to fit it correctly.
The More People I Meet, The More I Love My Dogs! |
Any body know if i can get a NEW ACC Molded Automatic carpet to fit my Manual trans hump floor, or should i return it for the Manual carpet?
Might be able to work it out if you have a console to cover the cutout for the shifter porch.
No console. Just Shifter Boot & ring. My 2003 carpet is for Manual and has been baggy around the Manual hump and between the seats.
You can always try it. As long as you don't cut it I guess no real harm done.
Rambow, I have done some more research and have been able to see an original '68 GTO carpet. It is cut so that there is a bare space of about 4" by 12" between the seat supports under the front buckets. Also, the binding does not go completely across the carpet like the replacement carpets. In fact, it is offset. The binding over the hump I several inches closer to the front than the binding at the edges. I have also seen an original carpet in a '69 Judge that is cut the same. Evidently, GM decided to save about 6 inches of carpet per car. If anyone is planning on entering Concours judging it is best to have the carpet cut as original.
My chance is now to put in a new MANUAL hump carpets ( the new AUTO hump carpet i accidentally ordered, is being returned) ACC carpet said " the AUTO hump carpet won't fit the Manual hump, so return it for $30 shipping. I've done a few 68 & 70 GTO/ LeMans carpets the past 35 years but only had this 1 baggy hump carpet from 13 years ago. Trouble is not knowing how i did it correctly all the other times. Think it a matter of paying attention and using great lighting during the install. Has there been a Thread response that described how to get a tight fit? |
Back in the day (late 80's), there was no difference between manual and auto repop rugs, it was one rug fits all 68-72 A body for $70 at the swap meets. I've got an auto rug I put into my 69 4spd back in 07, just a matter of cutting the jute out of the way and careful trimming on relief cuts under the console. wouldn't work as well without the console to cover up the stretch though. |
