Is this a #16 head ?
Is this a 16 head ? Or is further info needed.
Thank you. |
May be a 16. Probably late 67 casting.
What's the Date code? I have seen some early 68 heads cast on one side of center ports like this. I may have some 15 heads like this. Sent from my Moto Z3 Play using Tapatalk
You never know what I might have that you are looking for. EMAIL me. Also check out my other ads here on PY. Just click on user name to view other ads. USPS Money Orders or Wal-Mart to Wal-Mart money gram wire transfer -preferred payments. If Payment doesn't show up in 3-4 days, I move on to the next person that wants it. Serious Inquiries Only - Shipping Isn't Free. |
I can’t quite make out what part of the head I am looking at there.
Is that the top of the center exh ports? In terms of D port heads there where two different year 16 castings. One used in 1968 and will have screw in rocker studs and one used in 1970 that will not have screw in rocker studs. The casting date is below the exh side valve cover lip above the spark plugs. The 1970 heads will have chambers that will be about 6 CCs larger then the 68 heads. And will have 1.96” intakes and 1.66” exh valves.
...or is that a 97...?
Dennis |
X2 on the early 68' heads having the whole casting numbers on just one side of the center exhaust port "V". I've seen it a few times over the years.
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
Is there the other head that might have a clearer casting number?
Pic is not too clear
Pic is not very cleat it’s the #16.
I could not find a pic of other heads casted like that. |
There is a thread here on PY about I think 62 head codes that are cast upside down?
If the date codes are appropriate for 68 heads, it is probably a 16 head.
The Following User Says Thank You to johnta1 For This Useful Post: | ||
found pic:
Here is a example of early 68 head casting number.
This is a 68 #15 head. These early heads from the outside look like earlier cast heads with blank smog rail. The date code is right below valve cover lip. These earlier cast heads are harder to find if you happen to have a cracked head. The outside casting difference stands out compared to later 68 castings. Post date code from the 16 head you have. Sent from my Moto Z3 Play using Tapatalk
I have a pair of those upside down 62’s. Problem is some previous owner took a grinder to the chambers and ports and now they’re mostly a decorative conversation piece. Sent from my iPhone using Tapatalk |
Vid, can you post up some pictures of those heads?
They may not be a lost cause .
