Old 05-30-2022, 03:00 PM
8453johng 8453johng is offline
Default Steering Column connections?
I have got my column rebuilt and ready to install
I posted 2 pictures I am trying to find where the connectors attach to the column
The first picture on left the black 2 prong I place tape and wrote in past / goes to the white box on column (Ignition Switch) but which 2 connections the white box and where ? has 3 rows from the Column outward
Any help as always greatly appreciated
Name:	steering column.jpg
ID:	591798   Click image for larger version
Name:	steering column 2.jpg
Old 05-30-2022, 03:30 PM
The third picture looks like the white plugs in to the ignition switch but the black plug next to it does not
I have the manual but does not show the steering column connections
I think it is going to be a piece by piece fix
Thanks AgainClick image for larger version
Name:	steering column 3.jpg
Old 05-30-2022, 09:45 PM
Trevor78 Trevor78 is offline
What year model? Looks like relay plug, cig lighter plug and auto detent. Is this the 1980 still?
Old 05-30-2022, 11:27 PM
Default thanks
Sorry 1980 pace car ta
Old 05-31-2022, 03:26 AM
OK try again, now on larger screen.
The orange /brown plug with extended locking tab is the digital clock option, which on nearly all models is unused.
Most of the steering column group plugs are not shown, large black harmonicas that go with the white block.
The cross shaped plug in same pic as the digital clock looks like ones of the warning buzzers, can't see which wires are for it.
The flat plug with green and blue wiring, the one is said was the NSS, is actually for the backup lights next to it.
Do you have a wiring diagram? Make it easy to ID random plugs.
Old 06-01-2022, 08:11 PM
Default Thanks for the help
Still trying to figure out
Old 06-03-2022, 08:02 PM
Default Problem Solved
Got with Joe from TTA Performance and it took almost an hour on phone but got everything figured out.
He is an incredible knowledgeable person on Pontiac Trans Am
Thanks Again Joe from TTA Performance
