Old 11-20-2021, 06:36 PM
grivera's Avatar
grivera grivera is offline
Default A little end of season test/tune at Capitol Raceway in Crofton, MD
I went to the track today with temps in the mid - high 40s. There were two car clubs there but managed to get 5 runs in. Lots of 11 second cars there. I used MT 235 60 ET streets first at 25 lbs then down to about 22 lbs. I left car in drive for all runs and it shifts at about 5200 rpm. On engine dyno high HP was at 5373 rpm so some tweaking to do.
My best runs were 12.22 @ 112 mph and 12.25 at 113 mph. The 12.25 run I spun through the 60’ but the launch felt best out of all the runs. Overall had lots of fun and it’s the first time to track with this engine.
12.22 @ 112 mph run: https://youtu.be/mMQa4OmapXE
12.25 @ 113 mph run: https://youtu.be/jmc_Q_mGs4o
ID:	578234   Click image for larger version
Will Rivera
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears
The Following User Says Thank You to grivera For This Useful Post:
Old 11-20-2021, 07:21 PM
Va68goat's Avatar
Va68goat Va68goat is offline
mediocre driver, decent times, great car...excellent cameraman! That was a blast. I'm looking forward to spring already! Good times!
Old 11-20-2021, 07:24 PM
grivera's Avatar
Hahaha- definitely limited by driver experience! Thanks for coming out and catching the video evidence!
Will Rivera
Old 11-20-2021, 07:49 PM
mchell's Avatar
mchell mchell is offline
Nice!…..looks like you had a cool day with a bit of a tail wind to boot…can’t beat that for a day at the track!
Curious, what did it make on the dyno?
Wo…. Looking at the DA you had today!…. Negative 1000 ++DA with water grains in the teens and a 15 mph tailwind!!! One of those magic days! Dang!
71 GTO, 463, KRE 295 cfm heads ported by SD Performance, RPM intake, Qjet, Dougs Headers, Comp cams HR 246/252 ...11 to 1 , 3.55 cogs, 3985lbs.....day three- 11.04 at 120mph ....1.53 60', 6.98 1/8 mile
Old 11-20-2021, 07:59 PM
grivera's Avatar
521 hp/632 tq
Will Rivera
Old 11-20-2021, 08:20 PM
i82much's Avatar
i82much i82much is offline
521 hp/632 tq
those seem like great dyno numbers, did you have headers or manifolds on dyno?
Old 11-20-2021, 08:23 PM
mchell's Avatar
521 hp/632 tq
Very nice!
Old 11-20-2021, 08:32 PM
grivera's Avatar
Headers and a 950 hp carb. The Sniper is only 800 cfm so thinking about moving up to the xflow which is advertised at 900 cfm.
Will Rivera
Old 11-20-2021, 09:02 PM
i82much's Avatar
awesome, thanks!
Old 11-21-2021, 12:24 AM
scott70's Avatar
scott70 scott70 is offline
Well the mph is showing enough power to get into the 11's,,,,just need a little better 60ft
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
Old 11-21-2021, 02:15 AM
Brian Baker's Avatar
Sounds good, Will. How far "just south of Baltimore" are you? You cruising to Deale on Thanksgiving Day for the pie run?
Old 11-21-2021, 07:55 AM
grivera's Avatar
Hi Brian - I’m in Jessup (AA County side). Just heard of the pie run last week - what time does it wrap up? Have some work to put in at home in the kitchen to help my better half and if I can pull off both I will!
Will Rivera
Old 11-21-2021, 10:43 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Great job and you need to wind it out more next time.
Chris D
69 GTO Liberty Blue/dark blue 467, 850 Holley, T2, Edelbrock Dport 310cfm w Ram Air manifolds, HFT 245/251D .561/.594L, T400, 9" w 3.50s 3905lbs 11.59@ 114, 1.57/ 60'
Old 11-21-2021, 10:58 AM
grivera's Avatar
I agree - it has the factory shifter and has that “dual gate” type function where you can lean the shifter to the right run through 1-2-3. I haven’t learned how to use it so kept it safe. I may play with weights in governor for higher shift point.
Edit- just found this link on how to use it: https://youtu.be/_XOF7l4Cv7M
Will Rivera
Old 11-21-2021, 11:02 AM
ErikW's Avatar
ErikW ErikW is offline
Try 16 to 18lbs in the tires next time out. All of our cars like that pressure zone. 66 lemans, 71 T/A and 86 firebird. Nice numbers. Looks like it's running great.
1964 GTO
9.76 @ 137mph
1966 LeMans. 462, SD prepped Kaufman D ports. 11.90 @ 112
1976 Trans Am twin turbo 462, SD Edelbrock heads 8.50@159
2009 G8 GT
The Following User Says Thank You to ErikW For This Useful Post:
Old 11-21-2021, 11:46 AM
cnc's Avatar
cnc cnc is offline
Way to go …..Feels good to get out doesn’t it !!!!!!
1973 Firebird Navajo Orange w/shaker,1973 400/461,1972 Intake SD CNC'd,1977 Q-Jet 800 CFM w/ Cliffs Kit,Tanks Inc PA4 255 Walbro intank pump ,-8an feed/return,RobbMc Regulator,RobbMc 40 micron filter,253 CFM 6x-8's w/H.S 1:5 Roller Rockers,SD Stump Puller H/R Cam 230/236 @.050 112 lobe separation 565/.570 lift,Crower Solid Rollers,28150 Hedman Headers,3" exhaust,full tailpipes,350 Turbo,9.5" 3200 Converter,3:42 gear,8.5 posi,C/E slide-alinks,Koni adj frt shocks,Best 12.18@110.55 Lookin for 11's
Old 11-21-2021, 11:49 AM
grivera's Avatar
Big fun, Chris! Can’t wait for the spring time to do again. ET was what I was hoping/expecting based on combination of parts and first time out with the combo. I see you’re knocking on the door of an 11 second pass!
Will Rivera
Old 11-21-2021, 04:00 PM
mchell's Avatar
I use the same stock ratchet shifter that allows you to push to the right while up shifting. Works so well I haven’t “upgraded” to something else….
Your track having timing issues that day or is it the norm for them to only print the 60’, 1/4 and mph?
Old 11-21-2021, 05:33 PM
grivera's Avatar
Not sure why the printing issues…this track had been closed for several years and reopened this summer by Hurricane Racing Tours. Nice people but to say they are disorganized would be an understatement.
Will Rivera
Old 11-22-2021, 04:41 AM
It's an early gathering. In years past I've gotten up early and trekked down there to get there by 7:30am as it's roughly an hour drive from the Glen Burnie area, and if you're not there early there's no place to park. It's usually wrapped up by 10-10:30am. They're calling for sunshine and a high of 60 Thanksgiving Day so it looks like the weather will cooperate. I've been down there when it was 70 and we were sweating in our winter jackets, and I've been down there when it was colder than a well diggers butt in the Klondike with spots of salt on the roads here and there.
