Old 12-06-2021, 03:25 PM
Tom Vaught's Avatar
Boost Engineer
Originally Posted by GTOGEORGE View Post
I’m thinking Brian only ran mid 8’s at 13 lbs of boost! GTO George
You would be a second off with your memory of Brians boost level or performance. He was always in the 25+ psi boost area.
This has been his "footer" on his posts since 2016
"Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs)"
7.49 at 180 3365 lbs. Heavier than your car and quicker since 2016. Racing "Boost" again George???????
The topic is about Procharger superchargers, not BDS Roots supercharger stuff.
Tom V.
AGAIN, for the Original Poster, pm me and I will provide Brian's phone number.
Old 12-06-2021, 04:07 PM
GTOGEORGE's Avatar
Just curious............why procharger type supercharger?
GTO George
Old 12-06-2021, 04:33 PM
GTOGEORGE's Avatar
Tom V.
Since 2016.............LOL! He has been racing before that and at the Pontiac race at Norwalk with a pro charger with the boost i mentioned or close.
I don't race boost............I race the opponent next to me, since YOU brought it up and I NEVER brought up boost!
GTO George
Old 12-06-2021, 04:37 PM
GTOGEORGE's Avatar
Originally Posted by grandam1979 View Post
I’m thinking about a supercharger where is the best place to purchase it? The most complete kit to put on a traditional Pontiac 455. Thanks.
How much boost are you plan on running and how quick do you want to go?
GTO George
Old 12-06-2021, 05:10 PM
Stan Weiss's Avatar
GTO George
GTO George
Really!!! NEVER brought up boost.
Stan
Pontiac Pump Gas List
Old 12-06-2021, 05:21 PM
GTOGEORGE's Avatar
Stan
Actually Tv brought up Boost AND that number in post no.4, i was just repeating his numbers!
GTO George
Old 12-06-2021, 08:17 PM
Tom Vaught's Avatar
Boost Engineer
Mods, please remove my posts and the posts of anything other than directly speaking about Prochargers and let the guy talk to Brian Hedrich.
PM to the OP with the same suggestion.
Tom V.
Old 12-06-2021, 09:36 PM
grandam1979 grandam1979 is online now
GTO George
I honestly don’t know I would like the car to run high-mid 9’s and be drivable. 3600# 68 Firebird.
Old 12-06-2021, 09:46 PM
Tom Vaught's Avatar
Boost Engineer
The basic Procharger or Vortech Units should make that request target very easy to accomplish.
Talk to Mark at Luhn Performance and look at the kits he offers for both Brands of the Centrifugal Superchargers.
Tom V.
http://www.luhnperformance.com/ati.html
GTOGEORGE's Avatar
E85 or what?
GTO George
Old 12-06-2021, 11:02 PM
E85 or what?
GTO George
Pump 90-93 what I can get locally.
Old 12-06-2021, 11:37 PM
R 70 Judge's Avatar
Tom V.
Tom, what would you consider to be the ideal compression ratio vs what would be the maximum allowable compression ratio?
What could you get away with boost wise running 112 octane race fuel? E85?
James
1970 Trans Am
Spotts Built 484" IA2, Highports, EFI Northwind
Terminator X sequential EFI fabrication and suspension by
Old 12-07-2021, 12:02 AM
Tom Vaught's Avatar
Boost Engineer
The ideal compression ratio depends a lot on how much power you want to make at what Pressure Ratio. Some on the board have run 40+ psi of boost pressure on E85 but occasionally have issues with head gasket durability. This is on a "street car" running against other "street cars" in the New York area. This is with a measured compression ratio of 8.5 to 1 and a very good boost timing curve map.
Some who probably would never run over 20 psi, can get away with higher static compression ratios on E-85 fuel that has been tested to actually be E-85 to E-87, not the E-85 fuel that is advertised as E-85 fuel and tests in the low 70s for numbers.
The 112 octane race fuel also has its variability. It depends on the supplier.
At one time VP Racing Fuel was the fuel of choice there.
Sorry I could not give you better info. I have no info on drag racing fuels.
Tom V.
The Following User Says Thank You to Tom Vaught For This Useful Post:
Old 12-07-2021, 01:39 PM
GTOGEORGE's Avatar
I would go with the E85 for a couple reasons............No.1 - supercharger cooling effect, you wouldn't need an intercooler the plumbing would be a pain in the neck (not as bad as a Turbo set up) but still a PAIN. a roots set up is pretty simple hence is why i went with it! No.2 - its less expensive a gallon then premium gas. No.3 - when I make a pass on a 80-90 degree day my 8-71 blower stays cool and my engine never gets over 175 degrees! when I was at Frankenmuths Autofest I could drive my car from the show car area back to the campgrounds and had no problems with heat, i could have driven it around all day if i wanted too! Just something to think about!
GTO George
