3 speed Trans Oil Capacity
Can someone tell me the oil capacity for a stock 3 speed manual trans. A friend told it was a little over a quart and its not close to the fill opening. Thanks
Should be around 3.5 pints (1.75 quarts).
Found this in a search: https://firstgenfirebird.org/forums/...&Number=269835
Thanks, I saw that too but I am pretty sure my trans is the Dearborn which is different from the saginaw.
The Dearborn heavy duty 3-speed should take 2 quarts.
Either way fill it until the gear oil trickles out of the fill port in the side of the case.
Thanks, that's what I thought but wasn't sure.
Make sure you use the right oil. You need the one for brass syncros. Not that easy to find these days. I screwed this up on mine and had to dump all the oil.
The Following User Says Thank You to Hokie1984 For This Useful Post: | ||
Thats what I put in, I didn't know there was a difference until the parts guy told me.
