RH Exhaust Manifold 65-66 GTO
There was a design change made on the RH (passenger side) exhaust manifold in ‘66.
The ‘65 RH manifold had a round casting at each end, whereas the 1966 had a revised, stronger casting at each end. 1) 1964 RH exhaust manifold. 2) 1965 RH exhaust manifold. 3) Factory photo of a 1965 GTO engine. 4) RH manifold on Scott Tiemann’s ‘65 show winner (Pontiac build). 5) Same showing the round front casting on the ‘65 manifold. My 11A Baltimore build ‘65 Survivor also has this round casting.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. |
The Following User Says Thank You to 60sstuff For This Useful Post: | ||
1966 RH Exhaust manifold
Photos showing the revised, stronger manifold casting at each end on a ‘66.
1) New 1966 GTO engine with the revised manifold. 2) My 01B Fremont built Survivor RH manifold. 3) Front of the ‘66 manifold showing the stronger/heavier casting. 4) Rear of the ‘66 RH manifold. 5) The 1967 also used this revised casting on the RH manifold.
Great info! Didn't know this. Thanks for sharing
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
The Following User Says Thank You to Gary H For This Useful Post: | ||
My '65 was a late build, mid July 1965, and it has that '66 revised stronger design right manifold. I'll take some photos of it this week and post.
The Following User Says Thank You to 65 421 TODD For This Useful Post: | ||
The round earlier castings are more elegant.
That is if an exhaust manifold can be considered elegant.
The Following User Says Thank You to b-man For This Useful Post: | ||
My 65 GTO was a late May 1965 build and it has the 66 revised stronger design right manifold.
