Old 06-15-2022, 06:14 PM
Yellow Bird Yellow Bird is offline
Default HELP with 77 core support
Does anyone have a picture of a 1977 Trans Am radiator core support attached to the front sub frame? I'm unsure how the bolt, washers and rubber grommets go. Any help would be much apprecitated.
Old 06-15-2022, 07:11 PM
Trevor78 Trevor78 is offline
Very straightforward if you have the right parts. If you can wait about 6hrs I'll post up a diagram when home.
Old 06-15-2022, 07:31 PM
Thanks so much. I'll wait for your response.
Old 06-16-2022, 03:04 AM
Here's the general set up for radiator support mount, aftermarket is similar.
Bolt from top through a rubber mounting cushion bush, nut underneath, rubber mount sandwiched between. Shims and washers as required, if at all. It will have adjustment in most directions so loosen off if installing fenders until location is good, retighten. Otherwise has enough flex in bush mounts to move on its own when tightened up.
Firebird radiator support bushings 1980 by Aus78Formula, on Flickr
Old 06-16-2022, 12:05 PM
Trevor, This is exactly what I needed. Thanks for taking the time to help with and contribute to this decades old project.
The Following User Says Thank You to Yellow Bird For This Useful Post:
