Old 01-15-2019, 10:33 PM
hobbygto65's Avatar
hobbygto65 hobbygto65 is offline
Default 63 LeMans Progress.
Slowly making headway on the 63. A few photos.
ID:	503046   Click image for larger version
ID:	503047   Click image for larger version
ID:	503048   Click image for larger version
ID:	503049   Click image for larger version
Old 01-16-2019, 12:06 AM
3fastgtos 3fastgtos is offline
Looks nice.
Old 01-16-2019, 10:50 AM
OCMDGTO's Avatar
OCMDGTO OCMDGTO is offline
Looks good and going to be a fun ride.
Chris D
Old 03-08-2019, 06:50 PM
sberbs's Avatar
sberbs sberbs is offline
Looks great keep the posts coming with it
Sent from my Pixel 3 XL using Tapatalk
Old 03-11-2019, 12:06 AM
blueghoast's Avatar
Nice project, Is this going to be a back half car (tubbed)
I ran a 4-speed in my 62 for a while, It'll be fun for sure.
Keep the pics coming.
GT.
Old 03-12-2019, 12:49 AM
hobbygto65's Avatar
3.50 9" posi, no tubs just the biggest tires I can fit under it.
Old 03-13-2019, 07:40 PM
blueghoast's Avatar
That's cool, Another guy on here got a pretty big tire under his.
It was like 12.5 or so with the right back spacing.
It was R70 judge. Look up one of his old post. Looking good and a 4-speed too.
GT.
Old 03-13-2019, 08:12 PM
tom s tom s is online now
I ran 28X10 MT full slicks with a 57-58 pontiac rear and no tub or surgery.Tom
Old 03-15-2019, 09:04 PM
sberbs's Avatar
I'm going with the 428 with ported 62s and a 9" with 4.11s. 200r4 for the tranny
Old 03-16-2019, 02:27 AM
hobbygto65's Avatar
I would have run an automatic but I got such a good deal on a M22 Muncie I couldn't pass it up. What offset are you guys running with stock wheel wells?
Old 05-19-2021, 09:55 PM
hobbygto65's Avatar
Update, finally got the four link completed, New wiring harness is next. Also went with 275x15 BFGs. The fit dead center with 4" backspace Weld wheels.
ID:	566916   Click image for larger version
ID:	566917   Click image for larger version
ID:	566918   Click image for larger version
Old 05-20-2021, 07:18 AM
Radman's Avatar
Radman Radman is offline
It looks like the front end of your upper bars of the 4 link are higher than the rear at the axle. That will cause wheel hop on hard acceleration. Try to get the front of that upper bar lower than the rear of the bar.
If you built it, drive it.
red 62 Tempest total stock restoration.
white 62 Tempest modified, 61 389 Tri-Power, and a conventional drive train.
Old 05-20-2021, 02:18 PM
hobbygto65's Avatar
Thanks for the tip, I plan on getting ride height set after I get more weight on the car. Its pretty light right now with nothing in it.
Old 07-07-2021, 01:02 PM
sdbob sdbob is offline
When you painted black on frontend did you spray? Brand of paint? Noticed discs on back, brand? Thanks looks good.
Old 07-08-2021, 02:15 PM
hobbygto65's Avatar
Black is just krylon from a rattle can. Brakes are kit from Classic city auto glass, you get rotors calipers adapters brake lines and emergency cables for $300.
Old 07-08-2021, 06:10 PM
Thank you. I bought scarebird s front discs. He has rears for my 57 Olds rear, but different rotor stud pattern. I guess I could redrill.
Old 09-02-2021, 04:10 PM
hobbygto65's Avatar
Body shop finished the floor in my car this week. Didn't need the braces.
Old 09-02-2021, 08:36 PM
tekuhn tekuhn is offline
Very nice!
Hoping to finish a project while I'm still able to push the clutch in....
1963 Tempest Convertible (195-1bbl, 3-speed transaxle. 428 RAIV, 5-speed, IRS planned) Pictures
Old 10-26-2021, 03:26 PM
hobbygto65's Avatar
Getting some work done on the body. Really hard to find a body shop thats not a year out.
ID:	576208   Click image for larger version
ID:	576209   Click image for larger version
ID:	576210   Click image for larger version
ID:	576211   Click image for larger version
The Following User Says Thank You to hobbygto65 For This Useful Post:
Old 10-26-2021, 09:06 PM
Looking good! Any progress is good progress, as far as I'm concerned.
