Fan shroud installation
When I got my car, it did not have a fan shroud, and someone decided to bend the brackets WAY out. Today I bent the brackets back, BUT as they are now, there is a gap between the shroud and the radiator. Is the shroud supposed to sit directly on the radiator or should there be this gap? Take a look at the pics.
461ci, Edelbrock 72cc heads, KB 15cc dished pistons, comp xe274, PRW 1.5 roller rockers, Performer RPM intake, Holley 80508 750cfm, RARE oversized manifolds, Pypes X-pipe Exhaust |
Is that supposed to be a stock shroud or an aftermarket universal type? Karl |
It's a Tempest Custom cloned into a GTO. I have a 455 and an alum radiator that is a little thicker than the stock 3 core that used to be in there.
I got the shroud from a Pontiac company that is not our host (shhh) - its supposed to be a stock shroud that fits Pontiacs 64 - 67 or something. The gap is like a 1/4" to almost 1/2" from the shroud to the radiator. Without the brackets, I can see how it would directly fit against the rad in order to keep airflow smooth. I just want to make sure I need to bend the brackets in more to get it to the right place.
Karl |
Agreed with 72, 1/4 gap won,t hurt a thing, My 67 GTO wraps around outside of radiator and sits flush but in a few spots i have a 1/8 gap.
Karl |
Here is what an umolested 67 looks like. Your's should be about the same.
Awesome! Thanks guys!!! I'll let you know when it pans out. I'm waiting for my fan to be shipped (its been backordered for a few weeks, PY says it should be here this week.
Installed everything today. Looks good! I haven't had her on the road, but I can feel a LOT more blowing through this fan. I tried my best to position it half in, half out.
and in addition to the shroud, there are the rubber baffles also used in ac cars. They go along way to facilitate blocking the gaps and increasing air flow through the radiator
Ah yes, when I talked to someone at PY, he mentioned them - said there was a kit with a bunch of blocking material, and said it wasn't necessary but could be my next step.
you went this far, whats a few mor bucks for a good safety margin
