THE LOBBY A gathering place. Introductions, sports, showin' off your ride, birthday-anniversary-milestone, achievements, family oriented humor. |
Yep, no other damage luckily.
Atleast no one was hurt and no damage, pretty lucky.
78 T/A 4SPEED, Original paint, match #’s, mine since ‘99. 77 t/a sold 85 Monte Carlo SS sold 83 Mustang GT sold |
Glad everyone is okay and the damage is repairable.
This same failure happened to my 67 GTO to the previous owner. The underside of the front frame crossmember had gouges, the core support and fenderwell had some mangled sheetmetal from the "loose wheel". Messy failure.When I restored the car I noticed one lower arm had the classic junkyard yellow marker writing so it was a used replacement. I try to keep an eye on those arms once in a while.
Dave http://www.squidsfabshop.com/? (updated January, 2013, Pypes exhaust installation) |
Damn good thing he was driving at slow speeds, that would have been bad otherwise. Never seen a failure like that! Time for some inspecting seeing how I have an 1 1/4 swap bar on front and have pounded my car pretty hard.
DragStarLeMans |
Imagine if it happened while hard on the brakes at 60 mph.
Yep, glad no one was hurt and no major damage. |
This, and the earlier one, have something in common... Loose endlinks.
Poly is tough, and if you let it have a running start, it will pound the hell out of anything in it's path. And check out what the bolt did to the arm. |
X2. The ONLY time I have seen A arm failure on A body GM cars over the past several decades is when the stock rubber bushings were replaced with poly bushings. No thank you.
Jeff |
I have seen that on a Cadillac . wide radial tires put more load on that area than it was designed to handle .
End links did not cause this. Most likely a nick or gouge on the lower edge of the A-arm. Bottom edge of the arm between spring pocket and ball joint is of course under tension.
Neither photo shows much bending around the fracture. This is also surprising to me. I would expect the break to start along the bottom edge as you say, propagate up, then have the whole arm bend up. I wonder if these arms were made of something stronger than low-carbon steel? |
The Following User Says Thank You to U47 For This Useful Post: | ||
when first formed there are some ripples in the metal, if these ripples are smooth at the edge , but if there are rough or a jagged edge that is a possible point of fracture my bet is with this situation
JIM |
if the end links caused this then the crack would have gone to the end link hole.
I agree with Scarebird, don't blame the poly bushings. I would think that this has been cracked for a while, and slowly increased in size until it finally broke all the way off. |
