Old 06-16-2023, 10:57 AM
Default Vacuum advance connection.
I have a 1970 carb with a 1968 intake. On previous cars, I hooked the vacuum advance to a connection at the base of the carb. This carb has no such connection. How do I get a vacuum signal to the distributor?
ID:	614285   Click image for larger version
Old 06-16-2023, 11:19 AM
wbnapier wbnapier is offline
Somewhere on the carb or intake, you should have a vacuum port for full manifold vacuum. Post pics of all sides of both carb and intake. Do you have power brakes? If yes, they should be hooked up to full manifold vacuum. You can T off that port?
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
Old 06-16-2023, 11:28 AM
steve25 steve25 is offline
The steel fuel line into the Carb is so darn bent up and pinched off I would first be more concerned about fuel getting to the Carb then vacuum to the Dizzy!
The Following 2 Users Say Thank You to steve25 For This Useful Post:
Old 06-16-2023, 01:23 PM
It looks worse than it is!. Haha. It's just temporary. I have another on the way, but it takes forever to get here in the Great White North.
The Following User Says Thank You to 66sprint6 For This Useful Post:
Old 06-16-2023, 01:59 PM
Matt Meaney's Avatar
Matt Meaney Matt Meaney is offline
will a vacuum tree work?
https://www.yearone.com/Product/1967...m-parts/cf7274
“We don’t build a ‘luxury’ car. We build a performance car then we make it luxurious.”
Old 06-16-2023, 02:06 PM
jhein's Avatar
jhein jhein is offline
I run mine to manifold vacuum off the tree on the back of the throttle body for the brake booster. Works great. Great idle. Runs cool even sitting still at idle.
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
Old 06-16-2023, 04:32 PM
74Grandville 74Grandville is offline
you could add it like the factory did it. the biggest challenge is getting the hole the base plate in the right place. needs to be right above the throttle blade. you'll need to make sure the throttle pates are set correctly before drilling.
1979 Firebird Trans Am 301/4spd (Now 428)
1977 Firebird Formula 400/Auto
2007 Grand Prix GXP 5.3L
Old 06-18-2023, 04:53 PM
geeteeohguy's Avatar
You could easily install a hollow carb mounting stud as was used in earlier Pontiacs and get your distributor manifold vacuum source. A 5 minute job.
Jeff
Old 06-18-2023, 05:54 PM
I use to have 10 of these on hand from junk yard hunt days.
I would send you one if I still had any.
Old 06-19-2023, 08:49 AM
So full manifold vacuum to the advance can on the dizzy? It's not hard to create that, but I thought that it was metered.
