Spark plug gap vs Boost
Just curious what other people are:
Gapping their plugs at? At how much boost? What spark plug? and which fuel?
6.98 @ 199mph 4.53 @ 164mph |
NGK R5724-9, stock # 7891. Gapped .020, 12# boost, methanol.
Jim
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
I guess I should have said ours
Gapping their plugs at? .014 At how much boost? 39lbs What spark plug? 5671A-10 and which fuel? Q-16
Ditto except gapped at .034 and a very powerful ignition system. GTO George Last edited by GTOGEORGE; 10-10-2017 at 08:02 PM. |
.025 at 27 psi .
.020 at 35 psi Plug R5671A-8/4554 E85 fuel 6 al ignition box Want to upgrade to a 7 . 9.8 to 1
My Half AN Injun..... |
NGK -8 out of the box gap
E98 24psi E85 18 psi Old 6al and a Blue MSD coil |
.025 gap motor will pop like crazy @ 35 psi . .020 work just fine.....
.034 Seems huge. What are you running for ignition a mag?
I guess with 12 psi .034 will stay lit ....
What's your total timing with 39 psi?
Crane HI-7 but remember I'm not running a whole lot of boost.
GTO George |
Correction 27 Degrees I changed it at the last race.
cool!
GTO George |
Did it pick up with the 1 extra degree?
What's your static compression ratio ?
how much boost 10-12 psi, motor is 10 to 1 compression which spark plug 5671a-9 which fuel C-16 Timing 29 degrees, have a air to water intercooler also.
1965 GTO hard top, Black with a red interior built to drive and Race best so far 1.45 60’ 8.77@164mph . 6 Speed manual transmission. MS3pro Fuel injection Multiport , 517cubes 10 to 1, 3.50 gears, CNC E-heads wideport 350CFM by Dave B. 4025lbs with driver!!94mm turbo. Winner of the Hot Rod Dragweek stick shoot out 2017! |
Im happy to see that 12 A/F ratio is possible with 39 psi. That's 0.82 lambda for e85 . Im at 0.78 now . Ill have to trim it up some and see what happens .
Thanks for posting your log.
What's your cranking psi ? Im right around your ratio , just curious if its close to mine..
