Old 10-21-2017, 11:58 AM
Boostedbird's Avatar
Boostedbird Boostedbird is offline
Default New best
Just wanted to share with you guys. Went to the track last night. Ran it out once. It was breaking up some on the top. Needs plugs. I haven't changed them in a while, and forgot to take some. Left at 3,400 rpm on 2 step with about 1psi. Still on 10psi down the track. I tried to put 2 more psi in it later, but the track got worse and started spinning the tires down track. Not too bad for 3,800 lbs driving 31 miles each way to the track.
https://youtu.be/v16iUp3yxms
Name:	2017-10-21 10.27.08.jpg
Old 10-21-2017, 01:02 PM
dragracerx2813's Avatar
dragracerx2813 dragracerx2813 is offline
Nice pass !
Old 10-21-2017, 01:36 PM
73 TRANSAM 73 TRANSAM is offline
Nice run for the boost that your running. It looks like 9s are no big deal with boost. I cant wait for my junk to get done.
Old 10-21-2017, 01:58 PM
v869tr6's Avatar
v869tr6 v869tr6 is offline
Great to see you out with the car. Nice pass!
Old 10-22-2017, 10:48 PM
Turns out that I was only making 7-ish to 8psi. Went back to the track today and backed up my run. Checked boost on the way home today in the light. Gonna move my boost gauge closer and replace the blue led's with regular bulbs so that I can see the stupid thing at night. Anyway...
Old 10-23-2017, 12:29 PM
70 bird's Avatar
70 bird 70 bird is offline
Impressive number for low boost!
Old 10-23-2017, 03:23 PM
Curious George's Avatar
Curious George Curious George is offline
Awesome!
Whitmore 462, 670 heads 10.55@125
Same with 310 E D-ports 10.12@131
498 w/single 88 8.53@158
Old 12-08-2017, 11:08 PM
p4msi1's Avatar
p4msi1 p4msi1 is offline
Send a message via AIM to p4msi1
Gittin with it!
67 Firebird 3440 lbs, Pump gas 537 IA2, tiger heads, 4.86 rear, 32 x 17.5's, full interior, 4 mufflers, street shape 1.36 60', 6.11@113.42 1/8 mi. 5.67@123 on small shot.
Old 12-09-2017, 11:43 PM
Thanks everybody! The missing boost was caused by a header leak and a missing 1/8" npt plug from the turbine housing where I was testing backpressure. Though I met my build goals I was kinda bummed that I didn't get my 5 this year. I think that it should do it easy with normal boost next year, but I plan on stiffening the car up. As soon as the wheels come up the front sags and unloads the rear I think. I'm planning on a better cage with front bars to tie the subframe in better. Right now I can't leave with any boost. My buddies are wanting me to do a second gear leave th400. I feel that I should be able to leave with a few psi even if I have to use a boost controller to ramp the boost in slower. Idk.
