Old 01-14-2018, 04:35 PM
n2ogpsj462's Avatar
n2ogpsj462 n2ogpsj462 is offline
Default Hot side pipe
Some asked to see my hot side piping. I was able to leave everything as is when I pulled my motor so here you go. Everything is incredibly dusty from sitting in in my shop so long
ID:	472618   Click image for larger version
ID:	472619   Click image for larger version
ID:	472620   Click image for larger version
ID:	472621   Click image for larger version
71 grand prix SJ 4280# 462 new for 2008 -
8.7:1 , 98cc 6Xs 246/209, 342 12bolt , BW S475 turbo JGS 50mm WG 56mm BOV. 600hp the easy way!
Old 01-14-2018, 04:54 PM
Tom Vaught's Avatar
Boost Engineer
Looks like you did some nice fabrication work there with your single turbo set-up.
Reminds me a lot of the 60s/70s installations of the time.
Everything is nice and short and no extra volume in the exhaust system from "Magazine" pipe sizes. Nice Job.
What size turbo did you use for your install?
Tom V.
Old 01-14-2018, 07:33 PM
n2ogpsj462's Avatar
Its just the basic s475 with the 132 housing. I might do a round 2 build thread once my blocks back
Old 01-25-2018, 09:30 PM
greggutknecht greggutknecht is offline
I like how simple it is i think some people over think what they need for a certain hp level when building the hot side no need for actual headers below 1000 hp LS guys are making 800 with manifolds.
Old 01-26-2018, 01:13 PM
n2ogpsj462's Avatar
Thanks Gregg. I was going for the clutter free engine bay even tho I can literally stand between my motor and radiator in this boat. Everyone who sees my install says why didn't you run all the piping up front with all this room. I am however adding some cold side piping to try to get the hat at 6/12 oclock
Old 01-29-2018, 03:59 AM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
Good job on the routing! I like it ... I've always wanted to do a std. facing log deal.. Nothing beats the durability of the heavy logs !
*** THE BIG BRACE is here ***
Old 01-29-2018, 02:31 PM
v869tr6's Avatar
v869tr6 v869tr6 is offline
Glad to see you working to get the car out. So much power from a very simple and very usable set up, cool stuff.
Old 01-30-2018, 07:54 AM
Tom Vaught's Avatar
Boost Engineer
Hope you have a nice 3/8" radius on the PVC Inlet Pipe to the Turbo. A sharp edge at that location basically gives you 60% of the flow of a Radiused Inlet. Food for thought, let that turbo Suck.
Tom V.
Old 01-30-2018, 12:05 PM
n2ogpsj462's Avatar
I'm not sure I follow you Tom. Do you see a problem area? I think its 5" to 4" rubber reducer right off the compressor then about 2ft of 4" pvc then a 45° angle for air near the inner fender. Normally a 4" k&n style filter on the end for street driving but I made a chicken wire cap for the track (basically no filteration. Just keeps stones out)
Old 01-30-2018, 12:49 PM
RUDOLFSSON's Avatar
Looks like he' s referring to a trumpet type of a deal on the inlet of the piping...
Old 01-30-2018, 01:01 PM
n2ogpsj462's Avatar
At the end then where I have the screen cap? Usually have a filter there.
Old 01-30-2018, 02:35 PM
v869tr6's Avatar
My car club had a tech day at a air filter test lab years ago, the trumpet on the inlet of a pipe did make a noticeable difference.
Old 01-30-2018, 03:22 PM
Boostedbird's Avatar
Boostedbird Boostedbird is offline
Here is a little video with low airflow, but it does a good job to start to explain the importance of bellmouths in intake tracts. There's a good article in Dragzine I think about Procharger's work with their bellmouth. If I can find that one I'll put it here also.
https://youtu.be/sMn4i1pHSrg
Old 01-30-2018, 05:05 PM
http://www.dragzine.com/tech-stories...uth-air-inlet/
Here is the Dragzine article. It only looks at a bellmouth directly connected to the supercharger. Tom Vaught has already talked about the loss an open pipe end will experience. Just some stuff to look at.
Old 01-30-2018, 07:34 PM
n2ogpsj462's Avatar
Ahh ok. I have seen stuff on boards about them. In reconfiguring some things. Ill put that on the list thanks
Old 02-04-2018, 03:42 PM
Tom Vaught's Avatar
Boost Engineer
We have a great Boost Forum and MOST everyone tries to help Others on their boost packages.
Turbonetics 4" Radiused Inlet
Tom V.
Name:	4 INCH INLET.jpg
Old 02-04-2018, 04:05 PM
n2ogpsj462's Avatar
Nice. Now how far from the compressor or does it not matter? I constructed that 2ft of pvc so that I'm not pulling hot air from my manifold area.
Old 02-04-2018, 06:06 PM
taff2's Avatar
taff2 taff2 is offline
I've got two radiused ali bellmouths at my turbos inlets like in the Turbonetics photo, I then have a 6" ID hose clamped over the outer edge of the bellmouth which goes to a high pressure area at the front of the car.
Old 02-04-2018, 10:51 PM
How I did mine. Wanted to isolate the incoming air from underhood heat the best that I could. Drawing air from the area in front of the core support.
Name:	2018-02-04 21.39.28.jpg
ID:	474710   Click image for larger version
Name:	2018-02-04 21.39.56.jpg
ID:	474711   Click image for larger version
Name:	2018-02-04 21.40.18.jpg
