OHC 6 4bbl parts
I'm looking for an OHC 4bbl intake and exhaust manifold for my '66 Tempest. I might be interested in a carburetor and possibly a sprint cam. Let me know what you have.
Are you looking for a 66 specific intake/exhaust? I know I have an extra 66 Exhaust manifold, I will have to check to see if I have a 66 intake left. 66's are 1 year only parts, and won't interchange with 67-69 intake/exhausts. I know I have a couple of 67 4-bbl intake/exhaust manifolds left.
Let me know if you are interested in the 66 or if the later manifolds will work for you. Any year will bolt up to the head, 66's just have a different mating flange were the intake & exhaust manifolds bolt together foe the carb heat. I do also have a NOS "E" cam (67-68 4bbl cam, & 69 Auto 4-bbl cam) , but it would not be cheap. Sorry I am out of Carbs.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) |
PM sent
Jeff,
If John isn't after that 66' Exhaust man I would be interested as I have none for a 66' intake I have. LMK Thanks
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
1966 OHC Carburetor
I have a 1966 OHC carb for a Manual trans car, number is 7026261. let me know if you are interested. Restored $300 plus shipping.
Jeff, Let me dig it out, I think it is in the trunk of my 66 Lemans, and see how complete it is, and I will post some pic's of it.
Jeff,
Thanks JP, Very interested. Can you post some pics and give more info? i.e. replaced shafts? recolored? etc. If you can post here or email them to me that would be great. (email in bio) Thanks
I would be happy with a 67-69 intake/exhaust set. So, if Jeff needs that '66 exhaust manifold, go for it.
John, Here are some pic's of the 67-69 style manifolds I have, and Jeff I dug out the 66, and I would need $100.00 for it, it is almost perfect, it even has the thermostatic spring & stud intact, along with the choke coil. I will post some pic's of it also.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) Last edited by camerjeff; 04-14-2009 at 04:49 PM. |
John, here is a shot of the timing belt, and a side by side shot of a 66 & 67 exhaust manifolds. The are very simalur, but the flange were they mount to the intake manifold is more square on the 66, in fact the same shape the 1 bbl parts use 66-69.
Jeff here is the 66 exhaust I have left, as you can see all its missing is the Y-pipe & attaching studs. All the carb heat butterfly valve parts are there, as is the choke thermostat, but the rod is missing. Let me know.
Jeff R 60 Jaguar Mark 2, 3.8L Automatic 67 Sprint Firebird 230 OHC-6 4-Speed A/C 78 Catlina Safari, Pontiac 400 powered 77 Astre Formula, 215 Buick V-8 T-5 73 Lemans Safari, 400 4bbl 4-speed 71 Catalina Enforcer, 455 4bbl 06 Mallet Solstice #024 LS2, Now with a Tremec 6060 6-speed! 2012 F-150 Echo Boost (My local Ford Dealer SUX!!!) 2020 Dodge Charger Scat pack (recovered) Last edited by camerjeff; 04-14-2009 at 04:51 PM. |
Jeff,
Are the stud threads good? Can you give me an idea of shipping to 23462 VA BCH. Thanks
Jeff, I checked out the stud treads, 3 are perfect, and the last one could use a tap run throgh it, but they will work fine, And shipping to you will be included in the $100.00 price.
PM SENT.
I have an intake/exhaust assembly. It also has the y-pipe bolted to it and its all in good condition. Just old and rusty. I don't know much about these but it looks complete. I'll take $150 + you pay shippiong. I can ship FedEx pretty cheap from where I work. Not sure of the year. It's like the lower exhaust manifold where the two are pictured in this thread.
I have a 7027269 Carb for 67 OHC with a manual trans. It has been sitting for years in my basement. You can have it for $150. or I would trade for any round tag Q-Jet with a front inlet.
http://ultimategto.com/rest05cars1.htm |
Ross 455
If john does not take the parts, I might could use them . PM sent . Thanks |
