Old 06-21-2021, 10:17 AM
Kevspontiacs@aol.com's Avatar
Kevspontiacs@aol.com Kevspontiacs@aol.com is offline
Default Ngk plugs for 62’s
About to lose reception for the day and was wanting to pic up some plugs on the way home. What are you guys having luck with? 9.5 to 1 pump gas deal
Thanks in advance
Kevin
Old 06-21-2021, 11:46 AM
Plug needs are not by any means a matter of just the compression and fuel being used, but by the amount of HP being made!
Post up a ball park guess as to how much HP your thinking the motor will make, and also please post up the details of the motor.
Old 06-21-2021, 01:50 PM
Scott65's Avatar
Scott65 Scott65 is offline
XR5, stock number 3332. As a starting point, with no further info.
Old 06-21-2021, 07:38 PM
All right I’m back to having reception
Typical 400 build, 250ish 62’s, Lunati-voodoo hft cam (704 if memory serves me correct) 71(?) Intake, Quadra jet, try-y headers. It’s been a while since I’ve built it and don’t remember which coil is in it but I do remember putting the MSD module w/rev limiter in.
Old 06-21-2021, 07:52 PM
And as far as a horsepower guess it’s like I tell all the kids with the mustangs it was 185 factory so it might be 250 now Lol
Old 06-22-2021, 05:49 AM
Thanks much for the abundance of info!
I hope you don't mind that I put you on hold for a while as I set up my Crystal Ball, lol!
Old 06-22-2021, 09:17 PM
Dragncar Dragncar is offline
I have have very good luck with Accel 138 plugs in iron heads, 9-1 CR.
