#61
![]() Quote:
#62
![]() Quote:
let someone on fb slip up about sb or bb....the post will go from 6 comments to over hundred guys beatin on the same horse about it |
#63
![]() Quote:
Fair enough. My machinest had positive feedback over the E heads he has seen recently so maybe I got lucky on my two sets. Buy bare and use good parts, you will be fine. |
#64
My student building a 461 stroker in class ran it on the dyno tonight. IMO, it ran very well, didn't leak any fluids, and made very good power. Peak Toaque 590 ft. lbs @ 3500 RPM,, HP, 540@5600 RPM. Speedmaster assembled heads. Took the valve springs off and tossed them in the trash. Used everything else. Re-cut the valve job, cleaned them up a little. Performer RPM, Q-jet, HEI, Solid flat tappet cam. 251/259 Ultradyne. Nice package.
The Following 4 Users Say Thank You to mgarblik For This Useful Post: | ||
#65
My CNC HR spring SM checked out decent at the machine shop. They said the CNC is done here in CA.Springs looked like the Cranes Sd Performance uses. Just a stack of shims vs a locator.
Stuck a valve on our VW Bug years ago on the freeway!They used no guides in the aluminum head. Locked it up. Bought the bug for my wife as the horse barn was an hour away and her 454 truck got 9mpg! 7 pulling the horse trailer, but enough power you did not know it was back there! Did get a little scarey between gas station in AZ and N Mexico with just a 20 gallon tank making it to the next gas station movign from Houston and back to N CA.
Skip Fix 1978 Trans Am original owner 10.99 @ 124 pump gas 455 E heads, NO Bird ever! 1981 Black SE Trans Am stockish 6X 400ci, turbo 301 on a stand 1965 GTO 4 barrel 3 speed project 2004 GTO Pulse Red stock motor computer tune 13.43@103.4-sold 1964 Impala SS 409/470ci 600 HP stroker project 1979 Camaro IAII Edelbrock head 500" 695 HP 10.33@132 3595lbs 1964 Corvette Coupe 327 4 speed |
Thread Tools | |
Display Modes | |
