should be shot. Topic was to help my 455 pass the sniffer,someone said to put a whole gallon of washer fluid in a 1/4 tank,the methenal would help the sniffer,"IT WORKS!!!" I did so,almost instantly the damned thing wouldn't run. figured I would dilute the remaining contents of the tank,with 4 trips to the gas station with a 2 gallon can,got it enough to where I could drive it 2 days ago,went to the gas station filled it up. Put 2 cans of dry gas in it,got up this morning to take it to the track,and it won't stay running. Last day at the track,can't go. Lesson learned. Don't use someone else's advice,unless they have been there,done that. leave the half assed philosophys' to Socrates. (God I hope my spelling is correct)
And you said I got the wool pulled over my eyes, hahahahaha.
Less said,,,,,,,, Less mended. |
Charles,
I think very shortly you will be replacing EVERY rubber part in your fuel line system and the fuel pump and all of the carburetor guts. Alcohol and methanol are like death for normal fuel systems. Oh! I forgot the fuel sock in the tank. I got some alcohol mixed with gas one time in my tank and it melted the fuel sock and screwed the carb and fuel pump big time. To quote you: Been there done that. Have fun! Tom V.
The problem you are having with the windshield washer fluid is the fact that it is mostly WATER! The water is causing your no-run problems. You have to drain the tank and fuel system to get rid of it. After you do that, pour in a couple bottles of fuel dryer (iso, etho, or metho, alcahol) and re-fill with fuel. This should cure your problems. I really don't think you caused any other harm and you should not need to replace any lines or seals. Windhshield washer fluid? Now I HAVE heard everything!
Brakes?! We don't need no stinking brakes!
Never trust a fart. They sometimes suprise you. http://community.webshots.com/user/motornoggin http://motornoggin.smugmug.com/ |
Cpertice this is just another reason Not to got out drinking on Saturday night. 700+ posts Why didnt you ask us first. I appreciate your honesty and the ability to confess to your friends here. This sounds like another one I heard. I have a friend who wanted his car to be louder. Not me. But I will call him Bob anyway. Advise given get car up to normal engine temp and then run a garden hose up the exhaust and when the cold water hits the hot metal it will disintegrate the internals of the muffler. This sounded good to me I mean my friend Bob so he tried it. Mufflers did not get louder but the cracked head made it crack and pop some. Bob and I searched for weeks for another double hump Chevy head for a 64 Chevy and finally found one at an exuberant price. I uh I mean Bob paid for it and installed it never to try another wives tail again.
I remebmer years ago hearing that for cleaning the inside of the engine or for a sicky lifter run kerosene instead of oil in the crankcase for a few minutes as it is a light oil. Never thought I'd try that one.
I did put one gallon of racing alcohol to 1/2 tank of gas for an old Nova that wouldnt pass. Drove right through E-check
So let me get this straight: Your Honda has 1.6 liters and my bottle of Mountain Dew has 2? |
Cpertice, After you drain tank and line, Don't forget to pull off top of carb and clean out fuel bowl. The water will lay on the bottom of the carb even if you run it dry! Clean tank, line and carb BEFORE you refill fuel. If for any reason the motor still does not run as it should,This will have eliminated any chance of water being in the system.
My Grandfather used to run cleaner for an oil burner thru his engine. Drive it for a day then change the oil. I don't remember him ever having a problem with it.
My Rig's a little old, but that don't mean she's slow.
WWW.PatriotGuard.org Standing for those that stood for us. Only two defining forces have ever offered their life for you, Jesus Christ and the American G.I. One for your soul; the other for your freedom |
Windshield has very little methanol, like 5%, the rest being water. You have a gallon of water in your fuel tank, which must be drained. That small of a concentration of methanol for that short of time will not destroy your rubber.
What really works to pass a sniffer type test is a gallon of anhydrous isopropyl alchol (meaning on water, rubbing alcohol off the supermarket shelf has water, so is a no-no). Iso-Heat is one brand. Works great. Windshield washer fluid. Good Lord! |
He won't be happy 'til he blows up this 455 too [img]/infopop/emoticons/icon_wink.gif[/img]
I suspect whomever told you this never tried it. Alot of "hearsay" advise flying around as gospel.
Sad part is this advise came from this board! I suspect that the person posting didn't mean for him to use washer fluid just the methanol that is in it!!!!! Everything should be fine if you drain the tank Chalie!!!! All things will work out, you live and laern from your mistakes!!!! Let us know if you need a hand! [img]/infopop/emoticons/icon_wink.gif[/img]
bull! Show me the thread from this site that even comes close to recommending washer fluid in the gas tank.
I've been all over this board and...
12.24/111.6MPH/1.76 60'/28"/3.54:1/SP-TH400/469 R96A/236-244-112LC/1050&TorkerI//3850Lbs//15MPG/89oct Sold 2003: 12.00/112MPH/1.61 60'/26"x3.31:1/10"/469 #48/245-255-110LSA/Q-Jet-Torker/3650Lbs//18MPG 94oct Sold 1994: 11.00/123MPH/1.50 60'/29.5"x4.10:1/10"/469 #48/245-255-110LSA/Dual600s-Wenzler/3250Lbs//94oct |
Don't EVER put anything but gasoline in you GAS tank. Don't EVER put anything but Oil in your engine. Take it from an engineer, anything else is a gimmick or rip off. At best nothing will happen, at worst you'll ruin something.
