Old 10-08-2002, 12:43 PM
ichabod ichabod is offline
More bad news. disassemble engine. took to machine shop. The # 1 cylinder needs to be sleeved. Has anyone had this done and with what results in regards to longetivty and possible problems. This motor is a matching #389 to a 65 GTO tri-pwr. Any info on this procedure would be appreciated. Thanks
Old 10-08-2002, 12:47 PM
SCOTT ESTERLE's Avatar
SCOTT ESTERLE SCOTT ESTERLE is offline
Contact Pontiac Dude.
Old 10-08-2002, 12:52 PM
Guy Mazza's Avatar
Guy Mazza Guy Mazza is offline
I have had 2 (two) race blocks sleeved (1 rockblocked, 1 not) No problem w/either block. Id say it depends on who is doing the work. As long as you can find a competent shop...go for it! (esp w/a numbers matching block) Good Luck! [img]/infopop/emoticons/icon_biggrin.gif[/img]
A day without sunshine, is like night.
Old 10-08-2002, 01:21 PM
Old Man Taylor's Avatar
I had the same problem on my original 64 tri-power block. I had no choice but to sleeve it. After that experience I would not be at all reluctant to use another sleeve.
http://www.jimspontiac.homestead.com/Index.html
Old 10-08-2002, 02:36 PM
Brian Baker's Avatar
Definately depends on who is doing the work.
I had a sleeve put in a 455 over 4 years ago, followed by filling the block to within 1/2" of the water pump holes. Never had an overheating problem, or an oiling problem, and that engine is still running today in someone elses car. It went through 1.5 years of daily driving to work and 3 seasons of drag racing (making between 50-75 passes per season). And the kicker is the shortblock was assembled by an old man whom a certain engine builder in my area considers to be a "junk builder" (yet I've seen several of said engine builders motors blow up). If it is done right, it'll last. Depending on how much material they need to remove to insert the sleeve, however, you may have to fill the block to support that cylinder wall.
Old 10-08-2002, 05:58 PM
Sleeveing a block is completely acceptable, assuming a competent machine shop does it.
In fact some racers prefer sleeves over standard bores! They will actually have a perfectly good block sleeved on all cylinders to promote a more uniform wall thickness & promote a greater degree of reliability.
It is my understanding that the sleeveing can be done by press (interference) fit alone or along w/ welding.
SECOND AMENDMENT: AMERICA'S ORIGINAL HOMELAND SECURITY.
I Misus Rash'!
Old 10-14-2002, 06:32 AM
bob8748 bob8748 is offline
buddy is running 7.8s in the 1/4 with a sleeved block... No worries
So let me get this straight:
Your Honda has 1.6 liters and my bottle of Mountain Dew has 2?
Old 10-14-2002, 06:50 AM
rasilverbird rasilverbird is offline
I've got a sleeve as well. Car runs fine. Just make sure you clean out all the "slag" and shavings that might be left behind in your block.
Silver 1996 WS6 Trans Am M6
-daily driver
1968 GTO 400cid/TH400 ::455 ready to be built::
-sees some weekends
1968 GTO - 400/400 - Currently being rebuilt - 455/T56
1996 WS6 - LTI M6 - Sold 5/11
1979 Trans Am - 403/Auto - Sold 12/18
Old 10-14-2002, 04:51 PM
PONTIAC DUDE's Avatar
It doesn't matter and used both.
But a lot depends on where, how far, extent, degree and usege for repair and guarentee.
[img]/infopop/emoticons/icon_eek.gif[/img]
Q-16 Norwalk Qualifying 9.333@149.87
2nd Round, 9.303@135.13 ...Radials... hard on the brakes, Ray. LOL.
http://PontiacDude.cc
