Old 01-17-2022, 01:18 PM
racegto65's Avatar
racegto65 racegto65 is offline
I used this on my Firebird with long tube headers and a Wix 51258 filter.
My car has an automatic though.
https://butlerperformance.com/i-2495...l-rar-of2.html
Old 01-17-2022, 08:19 PM
I had the factory oil filter plate and housing that tilted the filter from downward to the rear,
(closer to the firewall). probably very hard to find one those factory oil filter "clocking"
adaptors but it has worked very well for me over the years. Headers or Cast Iron 67 iron
Ram Air manifolds. The Butler RAR-OF2 is a very good recreation of the same factory parts
I own.
ID:	582158   Click image for larger version
Old 01-17-2022, 10:56 PM
big matt's Avatar
big matt big matt is offline
Napa/wix gold 1522
1970 Formula 400 4 speed
2006 Gto. Ls2/m6
1972 Gto 455ho/th400 post coupe
1973 Grand Am 400 4 speed
Old 01-18-2022, 07:39 AM
64speed's Avatar
64speed 64speed is offline
The Purolator Boss filter for our cars is tiny. It’s like an LS filter. I have the Rona right now but today or tomorrow I will get you the part number
Old 01-18-2022, 08:04 AM
64speed's Avatar
PBL25288
Old 01-18-2022, 09:13 AM
chrisp chrisp is offline
Originally Posted by i82much View Post
I have a 65 four speed with round port doug's headers and mcleod bell. I run the HP2006 filter because the nut on the bottom makes life way easier.
Xs.-2 K&N HP2006
Old 01-18-2022, 09:14 AM
67Fbird's Avatar
67Fbird 67Fbird is offline
wix 51042. short small dia. ran into that with my lakewood bellhousing and hedman hustlers yrs ago.....never forgot. Not promoting WIX but the numbers are easier...lol
The 51045 is the tall version...depends on your headers if you can get it OFF!
Old 01-18-2022, 02:22 PM
Old Goat Racer's Avatar
The Exact reason I tell guys with true street cars to run RA manifolds over headers.FWIW,Tom
^^^ I couldn't agree more. You will never feel the difference in the seat of your pants !
Everybody knows somthin.
Nobody knows everything !
The Following User Says Thank You to Old Goat Racer For This Useful Post:
Old 01-19-2022, 01:47 AM
Dragncar Dragncar is online now
Originally Posted by Mike Davis View Post
Best one right here. Been running these for about 4 years now. Nice to be able to inspect for particles and wash and go.
https://kandpengineering.com/product/S16/
Did you get the one with built in by-pass and plug yours or get one without by-pass and kept the OEM one ?
Old 01-19-2022, 09:48 AM
Mike Davis's Avatar
Without the bypass and I plugged the factory one.
I bought an extra screen so I have always have a clean one at the track.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 01-19-2022, 12:51 PM
Fly GTO's Avatar
Fly GTO Fly GTO is offline
I use a NAPA 1042 or Wix 51042 (same thing) on my 65 GTO with Lakewood bell housing and RA manifolds. They are about the diameter of the oil filter housing.
Old 01-20-2022, 07:31 AM
Cliff R's Avatar
Cliff R Cliff R is offline
+2 for the Baldwin B-39 oil filter. It's shorter than most and full-flow without a check valve or bypass. It delivers the quickest response on your oil pressure gauge as well. I discovered them decades ago when Purolator quit making the shorter filter required to clear the Hedman headers on my Ventura's engine.
Before discovering the B-39 I tried several smaller filters often recommended on the Pontiac Forums and had issues with them. One actually failed inside some how and I lost oil pressure. Someone pointed me toward the Baldwin filter way back then and have been using them ever since on all Pontiac engines built here. I also block the bypass in the filter housing, but that's another topic that often gets varying info and opinions one way or the other.......
Old 01-20-2022, 03:16 PM
In talking to their tech people the flow rate is so much with their filter that they by pass in the filter or adapter have very little chance of ever opening.
I will probably get it without by pass and leave the stock one in just because thats what I have always done and had great luck with it. Its hard to change sometimes.
But I do not think it matters either way with their filter.
The extra screen is a nice tip, will do that.
Old 03-10-2022, 05:39 PM
Chris65LeMans's Avatar
Update:
The Mobil 1 M1 206A is what we went with.
Thanks, all!
