Old 01-07-2010, 12:50 PM
snakepitt1's Avatar
snakepitt1 snakepitt1 is offline
Send a message via AIM to snakepitt1
Default Headlight all on at once on low beams
1968 Firebird. When I turn on the headlights (low beam) the high beams slightly illuminate as well and this seems to keep the low beams from being as bright as they are capable of getting. When the high beams are activated, everything works properly. Could this be a bad flor mounted switch? Is it possible that this floor mounted switch is allowing electricity to pass through it during low beam operation to the high beam side? But only just enough to barely fire the high beams.
1968 Pontiac Firebird convertible, 400, Ram Air 3 heads, rebuilt TH350 transmission, balanced driveshaft, H-beam rods, forged pistons, Edelbrock performer cam, intake and 750 carb, new top, new interior, powdercoated frame, stripped and painted underbody, front disc brakes, complete MSD ignition. Hotchkis sub frame connectors. All this because I wanted a 4 barrel carb!
Old 01-07-2010, 01:41 PM
george kujanski's Avatar
Most likely a bad ground connection from the headlamps to the body and then back to the battery negative.
George
Old 01-07-2010, 01:45 PM
snakepitt1's Avatar
George
I added additional ground straps everywhere and made sure that I had bare metal under the connections. When the dimmer is tapped for high beam operation everything works perfectly, when tapping it back to low beam operation, the low beams come on but the high beam lights slightly illuminate as well.
Old 01-07-2010, 01:56 PM
Double check ground wires at headlights on both sides of core support.
All the federales say,they could've had him any day
They only let him slip away, out of kindness...I suppose
Poncho & Lefty
Old 01-07-2010, 07:15 PM
snakepitt1's Avatar
I'm going to run an additional ground strap from the core support directly to the neg of the battery.
