Old 08-02-2022, 07:49 PM
gtorich gtorich is offline
Default 66 gto trans mount
Yeah, i know bad pics, but im assuming this isnt a pontiac trans mount...........i bought a tkx 5 speed, and they said no solid mounts to the crossmember, which mine are..........im assuming this is a chevy mount since i have a chevy muncie in the car.........lol, you listen to the hype on these transmissons, can shift at 7 thou plus.............but dont mount them to the car, will break...........wow
Name:	Trans Mount (2).JPG
ID:	595644   Click image for larger version
Name:	Trans Mount (3).JPG
ID:	595645   Click image for larger version
Name:	Trans Mount (4).JPG
Old 08-02-2022, 08:44 PM
242177P's Avatar
242177P 242177P is offline
Moroso makes solid transmission mounts. I expect THAT is what they're afraid of.
You're overreacting, they don't care how your crossmember is mounted. HTH.
https://www.moroso.com/solid-transmission-mount62600/
Name:	moroso 62600.jpg
Old 08-03-2022, 08:18 AM
Thanks for the reply...........i will reread those instructions again, but this is what they sent in the kit, im trying to figure out if this is a pontiac cross member, i dont have those Insulators attatched to the end of mine...........not sure i could slip these on or not with what i have...............the pic in the ames book, that crossmember looks quite a bit different that mine. Not sure if i should just get a pontiac one and be done with it, or use mine.
Name:	Tkx trans mounts (1).JPG
ID:	595676   Click image for larger version
Name:	Tkx trans mounts (2).JPG
Old 08-03-2022, 09:08 AM
242177P's Avatar
Just use the crossmember you already have. Stop worrying about the sides, the only mount that matters is in the middle of the car, between the transmission and crossmember.
Old 08-03-2022, 09:57 AM
Got it, sounds good
